1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Multiple IOCs on a remote server
To: Abdalla Ahmad <[email protected]>
Date: Tue, 21 Dec 2021 00:07:43 -0800
The following repo may help you
HTH,
Han
On Mon, Dec 20, 2021 at 23:44 Abdalla Ahmad via Tech-talk <[email protected]> wrote:
I think you need to setup UDP broadcasting on the host, see this article: https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Make_Channel_Access_Reach_Multiple_Soft_IOCs_on_a_Linux_Host
P.S.: For some reason, I had to manually set the "$addr" and "$bcast" variables, they were not working for me.
Best Regards,
Abdalla.
-----Original Message-----
From: Tech-talk [mailto:[email protected]] On Behalf Of Randall Cayford via Tech-talk
Sent: Tuesday, December 21, 2021 9:34 AM
To: Gofron, Kazimierz via Tech-talk <[email protected]>
Subject: Multiple IOCs on a remote server
I’ve run into a problem I don’t understand.  I’m running 2 IOCs on a machine in a different subnet.   I can access the PVs by adding the remote machine’s IP address to my CA_ADDRESS_LIST.  However I can only access the PVs from one of the IOCs - the IOC that I start second.  Whichever IOC I start second. PVs from both are accessible from machines on the same subnet at the same time but only one set of PVs is accessible remotely.  If I restart the first IOC then it becomes the accessible one and the other becomes inaccessible.
I’ve tried setting up a cagateway on the remote machine and the behavior is the same.   Is there some trick to running multiple IOCs on a machine without which only one will respond to remote requests?
Randall
LBNL
Jeong Han Lee, Dr.rer.nat
Staff Scientist and Engineer
Lawrence Berkeley National Laboratory
1 Cyclotron Road Mailstop 46R0161
Berkeley, CA 94720, United States
Tel :+1-510-486-6163
Cell:+1-510-384-3868
Multiple IOCs on a remote server Randall Cayford via Tech-talk
RE: Multiple IOCs on a remote server Abdalla Ahmad via Tech-talk
Prev: RE: Multiple IOCs on a remote server Abdalla Ahmad via Tech-talk
Next: Job opportunity at PSI: Section Head Control Systems Schilcher Thomas (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
