Subject: |
RE: Multiple IOCs on a remote server |
"Manoussakis, Adamandios via Tech-talk" <[email protected]> |
To: |
tech-talk <[email protected]> |
Date: |
Tue, 4 Jan 2022 23:14:27 +0000 |
Depending what your linux OS is, I ran into issues with the script on ubuntu 18.04 and had to make a few adjustments to get it working.
Adam
The following repo may help you
I think you need to setup UDP broadcasting on the host, see this article:
https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Make_Channel_Access_Reach_Multiple_Soft_IOCs_on_a_Linux_Host
P.S.: For some reason, I had to manually set the "$addr" and "$bcast" variables, they were not working for me.
Best Regards,
Abdalla.
-----Original Message-----
From: Tech-talk [mailto:[email protected]] On Behalf Of Randall Cayford via Tech-talk
Sent: Tuesday, December 21, 2021 9:34 AM
To: Gofron, Kazimierz via Tech-talk <[email protected]>
Subject: Multiple IOCs on a remote server
I’ve run into a problem I don’t understand. I’m running 2 IOCs on a machine in a different subnet. I can access the PVs by adding the remote machine’s IP address to my CA_ADDRESS_LIST. However I can only access the PVs from one of the IOCs - the IOC that
I start second. Whichever IOC I start second. PVs from both are accessible from machines on the same subnet at the same time but only one set of PVs is accessible remotely. If I restart the first IOC then it becomes the accessible one and the other becomes
inaccessible.
I’ve tried setting up a cagateway on the remote machine and the behavior is the same. Is there some trick to running multiple IOCs on a machine without which only one will respond to remote requests?
Randall
LBNL
Jeong Han Lee, Dr.rer.nat
Staff Scientist and Engineer
Lawrence Berkeley National Laboratory
1 Cyclotron Road Mailstop 46R0161
Berkeley, CA 94720, United States
RE: Consolidate data from MTS to LTS in archiver appliance on demand Abdalla Ahmad via Tech-talk
Start IOC automatically at boot Donny Domagoj Cosic via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
