Mark,
These numbers were for our production IOCs which are being run on a cluster and using procServ.
I looked at an IOC run without any of this and it showed no growth in memory consumption. So I am working on investigating the differences between these set-up.
Thanks for your help.
John
Mark,
An IOC which is not acquiring from the camera grows at ~ 0.15 MB per minute. (resident memory grows, virtual memory is constant)
An IOC acquiring an image (1116x836, 5.5 Hz), no plugins, grows at ~ 0.24 MB per minute
[ note: 0.24 MB/min --> 10 GB after a month]
Enabling NDPluginStdArrays, NDPluginOverLay, NDPluginROI, NDPluginStats doesn't seem to produce additional memory growth.
John
Sorry, I should have said, Linux. I will investigate and report.
John
Hi John,
Is this on Linux or Windows?
Can you use “top” or other memory monitoring tools to see if memory usage increase corresponds to specific actions, such as stopping and starting the camera, errors about dropped frames, use of specific plugins, etc.?
We are using ADVimba with Mako G319B cameras. Over a period of three months memory usage has grown by an order of magnitude. Has anyone else encountered this?
Firmware Version 00.01.54.21000
[ I can try newer version of ADVimba in january.]
Research Support Specialist
Cornell High Energy Synchrotron Source
Start IOC automatically at boot Donny Domagoj Cosic via Tech-talk
Re: Start IOC automatically at boot Hu, Yong via Tech-talk
<2022>
2025
2026
Re: Start IOC automatically at boot Donny Domagoj Cosic via Tech-talk
Re: ADVimba memory leak ? John Dobbins via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
