1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: FLNK doesn't process
From: William Kirstaedter via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 18 Jan 2022 12:32:37 +0100
Guys,
Sorry, the "Fault" was intentionally:
Heinz Junkes silently set the ADEL and MDEL fields to 1.0E-9 which exactly does what we were observing.
It was just not documented on our side and I wasnt aware of the fields existence.
- W
William Kirstaedter (PP&B) Fritz-Haber-Institut der MPG
Faradayweg 4-6 14195 Berlin
Tel: 030 8413 5405 Mail: [email protected]
Am 18.01.2022 um 12:06 schrieb William Kirstaedter via Tech-talk:
Im hijacking this Thread because I have a similar problem but the suggested solution is not working.
we have the following db:
record(stringin, "$(P):$(R):getter"){
        field(DESC, "$(DESC) raw answer")
        field(DTYP, "stream")
        field(INP, "@maxigauge.proto getSensorValue($(CHA)) $(PORT)")
        field(SCAN, "1 second")
        field(FLNK, "$(P):$(R):Status.PROC CA")
record(scalcout, "$(P):$(R):Status"){
        field(DESC, "$(DESC)")
        field(INAA, "$(P):$(R):getter")
        field(CALC, "SSCANF(AA, \"%d%*\")")
        field(FLNK, "$(P):$(R):Pressure.PROC CA")
record(scalcout, "$(P):$(R):Pressure"){
        field(CALC, "SSCANF(AA, \"%*2c%E\")")
        field(PREC, "15")
        field(EGU, "mbar")
        field(ADEL, $(ADEL))
        field(MDEL, $(MDEL))
this ran fine until recently.
we dont know whats wrong now...
(original code was without ".PROC CA" and with PREC "12")
the problem is that the :getter PV continiously provides new values, while the :Status and :Pressure PVs slow down and stop updating when the Vacuum reaches Pressures in the Range <=1.0E-9.
>= 1.0E-7 its updating fast, around 8.0E-8 its only every minute or so and below it basically stops.
can anybody tell me why this is happening?
I first thought it was the unsufficient PREC but appearantly it isnt. :(
Thanks in Advance,
William
Am 15.01.2022 um 02:25 schrieb Randall Cayford via Tech-talk:
That worked.  Thanks!
On Jan 14, 2022, at 12:44 PM, Hu, Yong <[email protected]> wrote:
Change this line:
field (FLNK, "$(P):current1.PROC")
to:
field (FLNK, "$(P):current1.PROC CA")
From: Tech-talk <[email protected]> on behalf of Randall Cayford via Tech-talk <[email protected]>
Date: Friday, January 14, 2022 at 3:18 PM
To: Gofron, Kazimierz via Tech-talk <[email protected]>
Subject: FLNK doesn't process
I have a periodic scanned PV which I occasionally set.  However, when I set it, I can’t read the updated value until the periodic scan happens.  I would like the PV value to update as soon as it’s set.  I thought that was what was supposed to happen with FLNK but it doesn’t seem to.
My db has:
record (ai, "$(P):current1")
    field (DTYP, "stream")
    field (INP, "@thorlab.proto getcurrentch(1) $(BUS)")
    field (SCAN, "10 second")
record (ao, "$(P):setcurrent1")
    field (OUT, "@thorlab.proto setcurrentch(1) $(BUS)")
    field (SCAN, "Passive")
"caput setcurrent1 10" works but it takes whatever is left of the 10 second scan period before current1 changes.
“caput current1.PROC 1” immediately updates the value in current1.
I tried     field (FLNK, "$(P):current1”) but that doesn’t process either.
What’s the trick for getting a periodic scan PV to process within a forward link?  Or is there some other way I’m supposed to do this?
Thanks.
Randall
LBNL
FLNK doesn't process Randall Cayford via Tech-talk
Re: FLNK doesn't process Hu, Yong via Tech-talk
Re: FLNK doesn't process Randall Cayford via Tech-talk
Re: FLNK doesn't process William Kirstaedter via Tech-talk
Prev: Re: FLNK doesn't process William Kirstaedter via Tech-talk
Next: Errors during installation of StreamDevice Ewen Mallegol via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: FLNK doesn't process Ralph Lange via Tech-talk
