Hi, I got this error a lot. Many points : - is the kernel module well loaded ? lsmod | grep mrf - Depending on the CPU you use, you need to configure your PCIe virtual switch correctly.
With my configuration that is MTCA EVM300 andMTCA EVR300U I also had this problem because the CPU (NAT COMEX) hosting my EPICS IOC booted after the EVR and EVM. So the PCI configuration was not well done and produced this exact message you write below.
A manual solution is to reboot manually just your CPU to see if it's the problem. If it is, for me in the MCH (NAT MCH PHYS80) I have an argument "upstream slot power delay" that I put to 40 sec, meaning that my COMEx in RTM boot 40sec after the crate boot. (this work only with the latest version of the NAT MCH firmware)
ps : I prefer to use "lspci -nmmn" to list my PCIe device
Cheers
Alexis GAGET CEA Saclay DRF/IRFU/DIS/LDISC De : Tech-talk <[email protected]> de la part de gjzhai--- via Tech-talk <[email protected]>
Envoyé : jeudi 20 janvier 2022 14:52:33 À : [email protected] Objet : mrfioc2-PCI device Configuration Hello all I am trying to get MRF MTCA-EVG-300 and MTCA-EVR-300U configured and working on Linux using mrfioc2. I found geographic address(bus:device.function) in /proc/bus/pci/devices. The information is as follows: 0800 10ee7011 10 df100000 0 0 0 0 0 0 80000 0 0 0 0 0 0 pci_mrfevg 0900 10ee7011 11 df000000 0 0 0 0 0 0 40000 0 0 0 0 0 0 pci_mrfevr
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
