1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Calling the streamReload IOC Shell function within C
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Wang, Andrew" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 21 Jan 2022 21:08:19 -0800
On 1/21/22 19:39, Wang, Andrew via Tech-talk wrote:
This is a far-fetched question, but I was wondering whether there is a possibility of executing streamReload, or a similar functionality, within a C function. The reason why I ask is because I saw within this Github link (https://github.com/epics-modules/ioczed/blob/master/zzzApp/Db/streamExample.db <https://github.com/epics-modules/ioczed/blob/master/zzzApp/Db/streamExample.db>) that the SUB record calls streamReload. However, I couldn’t locate the source code for that, so I am not entirely sure how it is used and what its arguments are. Thoughts?
The registrar code adding both the function callable
from subRecord as well as iocsh.
https://github.com/paulscherrerinstitute/StreamDevice/blob/dfbd308d4602e7cb99d7f60ddf35909a70f41c4f/src/StreamEpics.cc#L297-L307
So you could do something like
iocshCmd("streamReload");
cf. iocsh.h from Base.
Since it is already callable from a subRecord I assume
it is thread-safe.
Re: Calling the streamReload IOC Shell function within C Zimoch Dirk (PSI) via Tech-talk
Calling the streamReload IOC Shell function within C Wang, Andrew via Tech-talk
Prev: Calling the streamReload IOC Shell function within C Wang, Andrew via Tech-talk
Next: Re: Calling the streamReload IOC Shell function within C Zimoch Dirk (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
