1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: p4p releases 3.5.5 and 4.0.0
From: Michael Davidsaver via Tech-talk <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 25 Jan 2022 13:19:36 -0800
I've uploaded two P4P releases.
https://mdavidsaver.github.io/p4p/
3.5.5 has only minor changes related to replacing nose with nose2.
The .whl files uploaded to pypi.org are also built against the
latest epicscorelibs wheels.
4.0.0 is a much larger change to replace usage of the pvAccessCPP
library with PVXS.  The P4P APIs mostly remain, so this will
hopefully be a mostly transparent change for most users.  Please
report any issues encountered (and/or suggestions for improvement).
As a note for those wishing to use p4p with python >=3.10.  The
asyncio frontend has not yet been updated to follow the removal of
the loop= argument.
https://github.com/mdavidsaver/p4p/issues/80
The thread, cothread, and qt frontends continue to work with 2.7
and >=3.4.
Prev: Re: Interrupt problem. Francisco Ramos via Tech-talk
Next: could you tell me how to cancel the toolbar when I deploy a opi file in tomcat by webopi3.3 ? 朱晨晨 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: RE: Adding a second output array to an areaDetector IOC Iain Marcuson via Tech-talk
