1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Use of asyn's setInterruptUInt32Digital in EPICS device support
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, Jure Varlec <jure.varlec at cosylab.com>
Date: Wed, 26 Jan 2022 14:48:04 +0000
Hi Jure,
> I’m looking at `asynPortDriver::setInterruptUInt32Digital()' which is documented to be “called when asyn clients call `pasynUInt32Digital->setInterrupt()'”.
> However, EPICS device support (`devAsynUInt32Digital.c') does not contain such a call.
You are looking in the wrong place for that call.  That call is not part of device support, it is part of the asynUInt32Digital interface, and so is present here:
pasynUInt32Digital->setInterrupt() is used to configure the driver to control which bits will generate interrupts.
It is implemented in the IPUnidig driver, for example:
> I’d expect, from the driver point of view, to be able to use `asynPortDriver::getInterruptUInt32Digital()' to learn which bits records are interested in.
No, it is the reverse.  Device support calls getInterruptUInt32Digital() to learn which bits the hardware has configured to generate interrupts.
• On read or write, `asynUInt32Digital' passes the mask and the value to/from in the way appropriate for the device.
Yes, that is true.
>  For interrupts, `asynPortDriver' will consider the mask given to `setUIntDigitalParam()' and figure out which `IO Intr' records to process based on both the mask and which bits in the value have changed.
Yes, that is true.  But this has nothing to do with driver/hardware interrupts, which is what setInterruptUInt32Digital() is designed to control.
> If the last point is true, then I guess `asynPortDriver::setInterruptUInt32Digital()' really doesn’t seem useful for EPICS. I hope now you see why I’m wondering what it’s about
You are mixing up software interrupts which are handled using callbacks for records with SCAN=I/O Intr with driver/hardware interrupts.  They are completely separate.  asynPortDriver::setInterruptUInt32Digital() only controls driver/hardware interrupts, which is why it is not used in many places.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Jure Varlec via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, January 26, 2022 2:32 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Use of asyn's setInterruptUInt32Digital in EPICS device support
Dear all,
call.
It’s not clear to me how this interface is meant to be used. I’d expect, from
interested in. However, this does not work with EPICS, I don’t see how it could
be set to logical-or of masks for all `IO Intr' records, and I don’t see a use
case for anything else. I don’t have a use case myself; I’m just wondering how
the interface works and what it is meant for, presuming that it was implemented
with some purpose in mind.
Actually, I feel a bit unsure as to how the mask in the UInt32Digital interface
really works. The documentation appears to be quite sparse on this topic. My
understanding is the following:
• `asynInt32' deals with the mask in EPICS device support layer support while
  `asynUInt32Digital' delegates that to the driver.
  the driver unmodified. It’s up to the driver to apply the mask to the value
• For interrupts, `asynPortDriver' will consider the mask given to
EPICS. I hope now you see why I’m wondering what it’s about :)
Best regards,
Jure Varlec
Senior Software Developer
Cosylab d.d.
www.cosylab.com
Re: Use of asyn's setInterruptUInt32Digital in EPICS device support Jure Varlec via Tech-talk
Prev: Phoebus - image on Boolean-Button Mogamad Amien Crombie via Tech-talk
Next: Re: [EXTERNAL] Phoebus - image on Boolean-Button Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Use of asyn's setInterruptUInt32Digital in EPICS device support Jure Varlec via Tech-talk
Next: Re: Use of asyn's setInterruptUInt32Digital in EPICS device support Jure Varlec via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
