1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: Adding a second output array to an areaDetector IOC
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Iain Marcuson <iain.marcuson at sydortechnologies.com>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Sun, 30 Jan 2022 22:17:57 +0000
Ø  I did try changing “addr” in the second call.  That did indeed keep pImage from being overwritten.
Ø  That did indeed keep pImage from being overwritten.
Do you really mean pImage was overwritten, or do you mean the waveform record in the NDStdArrays plugin?  The latter is what doCallbacksGenericPointer() writes to.
Ø  However, the data in pProfile were being overwritten.
Again, do you really mean pProfile (which is the source of the data, not the destination), or do you mean the waveform record in the NDStdArrays plugin?
What are they being overwritten with?
Ø  When I used an addr of 0, the pProfile data were correct (I used fixed values for debugging.)
Again, do you really mean pProfile was correct, or do you mean the waveform record in the NDStdArrays plugin?
Please send screen shots of both of your NDPluginStdArrays screens.
From: Iain Marcuson <iain.marcuson at sydortechnologies.com>
Sent: Sunday, January 30, 2022 4:05 PM
To: Mark Rivers <rivers at cars.uchicago.edu>; tech-talk at aps.anl.gov
I apologize for the long delay.  I did try changing “addr” in the second call.  That did indeed keep pImage from being overwritten.  However, the data in pProfile were being overwritten.  When I used an addr of 0, the pProfile data were correct (I used fixed values for debugging.)  However, when I used an addr of 1, the values coming from pProfile were very incorrect, despite having been written right before a getIntegerParam() and the doCallbacksGenericPointer(pImage, NDArrayData, 0).  I am unsure what would cause the issues I was seeing.
Sent: Monday, January 24, 2022 9:48 PM
To: tech-talk at aps.anl.gov; Iain Marcuson <iain.marcuson at sydortechnologies.com>
Subject: Re: Adding a second output array to an areaDetector IOC
Hi Iain,
Before answering your question, I have 2 suggestions:
  • NDPluginStats already has the capability of displaying profiles.  These can be the average profiles in the X and Y directions, the X and Y profiles at the centroid position, and the X and Y profiles at a user-specifed "cursor" position.
  • If you want to export a profile directly from the driver, I don't think you really need to use an NDArray for that, you can just use a simple 1-D array and a waveform record.
If you really do want to export an NDArray then you just need need to change "addr" in the second call to 1, because that is the addr you defined for the xprof profile.
       doCallbacksGenericPointer(pImage, NDArrayData, 0);
       // And call for profile
      doCallbacksGenericPointer(pProfile, NDArrayData, 1);
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Iain Marcuson via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, January 24, 2022 6:02 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
As an addendum, I was able to get $(P)xprof:ArrayData updating by doing
caput $(P)xprof:EnableCallbacks 1
although I still have the problem of the output data collision.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Iain Marcuson via Tech-talk
Sent: Monday, January 24, 2022 6:46 PM
Subject: Adding a second output array to an areaDetector IOC
I am working on a custom areaDetector IOC and also trying to learn more of the general areaDetector architecture.  For a first test, I have tried to add some profile functionality to the IOC.
I have started by creating an array for the output, following the example from mythen.
# Create a standard arrays plugin
NDStdArraysConfigure("Image1", 3, 0, "$(PORT)", 0, 0)
dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),NDARRAY_ADDR=0,TYPE=Float64,FTVL=DOUBLE,NELEMENTS=$(NCHANS)")
# Create a standard arrays plugin for column profile
NDStdArraysConfigure("XProfile", 3, 0, "$(PORT)", 0, 0)
dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$(PREFIX),R=xprof:,PORT=XProfile,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),NDARRAY_ADDR=1,TYPE=Float64,FTVL=DOUBLE,NELEMENTS=$(NCOLS)")
In the callback of the IOC, I create an NDArray for a column profile and populate the array.
When I run the IOC and start acquisition, $(P)xprof:ArrayData is undefined but of the correct size.  When I look at the image output in ImageJ, the display flickers between the full image and a one-row display of the profile data.  Some experimentation leads me to believe that the problem comes from the following lines:
if (arrayCallbacks) {
        /* Call the NDArray callback */
                doCallbacksGenericPointer(pProfile, NDArrayData, 0);
How can I get the two data separate?  Is the solution to make a profile plugin and feed the data to that?
Thank you,
Iain Marcuson
Software Engineer, Sydor Technologies
585.278.1168 | www.SydorTechnologies.com
Skype: iain.marcuson at sydorinstruments.com
This message has been scanned for malware by Forcepoint. www.forcepoint.com
Click here to report this email as spam.
Adding a second output array to an areaDetector IOC Iain Marcuson via Tech-talk
RE: Adding a second output array to an areaDetector IOC Iain Marcuson via Tech-talk
Re: Adding a second output array to an areaDetector IOC Mark Rivers via Tech-talk
Prev: RE: Adding a second output array to an areaDetector IOC Iain Marcuson via Tech-talk
Next: RE: Adding a second output array to an areaDetector IOC Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
