1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: Area Detector: print report from iocsh
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: David Vine <dvine at sigray.com>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 1 Feb 2022 19:53:02 +0000
Hi David,
Ø  How do I execute the report function from the iocsh for a camera? Eg AndorCCD::report
You use the asynReport command.
To see all asyn port drivers in the IOC with minimum details you omit any arguments:
epics> asynReport
PG1 multiDevice:No canBlock:Yes autoConnect:Yes
Number of cameras detected: 2
Image1 multiDevice:No canBlock:No autoConnect:Yes
Port: Image1
FileNetCDF1 multiDevice:No canBlock:Yes autoConnect:Yes
Port: FileNetCDF1
FileTIFF1 multiDevice:No canBlock:Yes autoConnect:Yes
Port: FileTIFF1
FileJPEG1 multiDevice:No canBlock:Yes autoConnect:Yes
Port: FileJPEG1
To see just the camera driver, in this case PG1, with minimum details:
epics> asynReport 0 PG1
To see more details increase the “details” argument from 0 to 1, 2, …, 20, etc.
epics> asynReport 1 PG1
    enabled:Yes connected:Yes numberConnects 1
    nDevices 0 nQueued 0 blocked:No
    asynManagerLock:No synchronousLock:No
    exceptionActive:No exceptionUsers 1 exceptionNotifys 0
    traceMask:0x1 traceIOMask:0x2 traceInfoMask:0x1
Camera 0
Device Vendor Name   (DeviceVendorName):
Device Model Name (DeviceModelName):Updater
Device Serial Number (DeviceSerialNumber):13481965
(DeviceVersion):
Device Type (DeviceType):GigEVision
Camera 1
Device Vendor Name   (DeviceVendorName):Point Grey Research
Device Model Name (DeviceModelName):Grasshopper3 GS3-U3-23S6M
Device Serial Number (DeviceSerialNumber):17475357
Device Version (DeviceVersion):FW:v2.22.3.00 FPGA:v2.02
Device Type (DeviceType):USB3Vision
Report for camera in use:
Feature list
      Node name: AccessPrivilegeAvailable
          value: false
      Node name: AcquisitionFrameCount
          value: Not available
      Node name: AcquisitionFrameRate
          value: 85.106384
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of David Vine via Tech-talk
Sent: Tuesday, February 1, 2022 1:29 PM
To: tech-talk at aps.anl.gov
Subject: Area Detector: print report from iocsh
Hi all,
David
Image removed by sender.
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
Area Detector: print report from iocsh David Vine via Tech-talk
Prev: Re: A Tribute to our Colleague Marty Kraimer Maren Purves via Tech-talk
Next: Omron Ethercat Motor Controllers bob dalesio via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Area Detector: print report from iocsh David Vine via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
