1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: .RE: Configuring serial communication with Lakeshore 331 via Moxa (Mark Rivers)
From: "Bradnick, Ben \(DLSLtd, RAL, LSCI\) via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, mark.koennecke <mark.koennecke at psi.ch>, Mark Rivers <rivers at cars.uchicago.edu>
Date: Thu, 3 Feb 2022 14:46:10 +0000
We have an EPICS support module that allows us to view and configure the mentioned port parameters of our Moxa and older ACS terminal servers using SNMP and uses autosave to store/restore the configuration.
I could upload it if there's any interest.
Kind regards,
Ben
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
Sent: 03 February 2022 14:18
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; mark.koennecke <mark.koennecke at psi.ch>
> And I always configure the serial port settings on the terminal server and just use the drvAsynIPPortConfigure() to talk to the device through the network.
> Much simpler that way, no need for cumbersome protocols.
The advantage of putting the serial port configuration (baud, bits, parity, etc.) in the startup script is that it will then normally be under source release control, and hence difficult to lose.   If the settings are only inside the non-volatile memory of the terminal server they are less likely to be recorded.  When the terminal server fails (and they do) the settings need to be recreated.
The protocol as implemented in drvAsynIPPort is not cumbersome: the serial port configuration commands in the startup script are identical to those for local serial ports, and the API for writing and reading data is identical, whether or not the COM modifier to drvAsynIPPortConfigure is used.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Koennecke Mark (PSI) via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, February 3, 2022 1:15 AM
Subject: .RE: Configuring serial communication with Lakeshore 331 via Moxa (Mark Rivers)
Dear Jakub,
I work with Moxa terminal servers a lot. We have a lot of 1990 style serial hardware…. And I always
talk to the device through the network. Much simpler that way, no need for cumbersome protocols.
Best Regards,
     Mark Koennecke
Re: .RE: Configuring serial communication with Lakeshore 331 via Moxa (Mark Rivers) Kevin Peterson via Tech-talk
.RE: Configuring serial communication with Lakeshore 331 via Moxa (Mark Rivers) Koennecke Mark (PSI) via Tech-talk
Re: .RE: Configuring serial communication with Lakeshore 331 via Moxa (Mark Rivers) Mark Rivers via Tech-talk
Prev: Re: .RE: Configuring serial communication with Lakeshore 331 via Moxa (Mark Rivers) Mark Rivers via Tech-talk
Next: Re: Configuring serial communication with Lakeshore 331 via Moxa Wlodek, Jakub via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Re: .RE: Configuring serial communication with Lakeshore 331 via Moxa (Mark Rivers) Kevin Peterson via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
