I am trying to connect a Basler camera with areaDetector. I saw in a previous tech-talk ( https://epics.anl.gov/tech-talk/2020/msg00388.php) that the aravisGigE and ADAravis modules
should work with basler. I would prefer to use ADAravis since it is newer and better optimized, but when reading the documentation, I saw that ADAravis explicitly states that it cannot be used on windows because the underlying library aravis does not support
it ( https://areadetector.github.io/master/ADAravis/ADAravis.html) but in the aravis documentation it gives instruction on how to install on windows ( https://github.com/AravisProject/aravis).
Then with aravidGigE the documentation says it works on windows but then only gives instruction on how to install on lunix.
The questions I have are
- Can ADAravis be used on windows?
- Given a set of instructions for installing on lunix how can I adapt those to install on windows?
Bryan
- RE: Connecting Basler camera with areaDetector on Windows Mark Rivers via Tech-talk
Re: [EXTERNAL] Creating a database record Vodopivec, Klemen via Tech-talk
<2022>
2025
2026
RE: Compilation of IOC using OPC UA device support DESMARCHELIER Gabriel via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
