1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: PV Seq not process everytime
From: GAGET Alexis via Tech-talk <tech-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 10 Feb 2022 08:00:25 +0000
Hi Ralph,
Thanks for your suggestion (and answering the CEA team all the day yesterday ;) )
Sorry I forgot to mention that i had tested the FLNK before (without the CP), the CP was my second solution to test if it was the problem.
MDEL of myPV1 is at 0...I've tried -1 yesterday just in case, doesn't change anything.
the problem is I wasn't able to reproduce the problem yesterday, except at the end of the day when beam started I have to find the causality of this correlation .... In the meantime I've noticed that when I'm processing myPV1, by reintroducing value in CSS, it process correctly the sequence, but get stuck few step later, BUT if I execute a dbtr of mySequence it seems to correct the problem until the next reboot of the IOC.
Any idea ?
De : Tech-talk <tech-talk-bounces at aps.anl.gov> de la part de Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
Envoyé : mercredi 9 février 2022 10:51:18
À : EPICS Tech Talk
Objet : Re: PV Seq not process everytime
On Wed, 9 Feb 2022 at 09:02, GAGET Alexis via Tech-talk <tech-talk at aps.anl.gov> wrote:
record(ao, "myPV1"){
record(seq,"mySequence"){
     field(DLY1,"0")
     field(DOL1,"myPV1 CP")
     field(LNK1,"mySetPoint PP")
     field(DLY2,"0.5")
     field(DOL2,"1")
     field(LNK2,"myCommand PP")
myPV1 is the destination i want to reach, each time I change it, it process this sequence to set the destination in mySetPoint, and 0.5s later to activate the command. It works well most of the time. But yesterday sometimes, myPV1 was changed but mySequence was not processed .... it causes the whole sequence (emittance measurement) to get stuck. It can be unstuck by processing "mySequence" but it's a long sequence and we don't stay in front of the computer.
Hi Alexis,
CP input links are using monitors. If you have a myPV1.MDEL setting, it could suppress changes to be sent to mySequence.
Unless you have a specific reason to use a CP inlink, you could also set myPV1.FLNK to point to mySequence. That would make this a very tight coupling, with the sequence being run basically as part of changing myPV1. (Remove the CP in mySequence.DOL1 in that case.)
Cheers,
~Ralph
Re: PV Seq not process everytime Hu, Yong via Tech-talk
PV Seq not process everytime GAGET Alexis via Tech-talk
Re: PV Seq not process everytime Ralph Lange via Tech-talk
Prev: RE: Connecting Basler camera with areaDetector on Windows Mark Rivers via Tech-talk
Next: Re: PV Seq not process everytime Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: PV Seq not process everytime Ralph Lange via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
