1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RecSync installation with python 3.6.8 and twistd 21.7.0
From: Jianming You via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 16 Feb 2022 19:35:08 +0000
Dear Experts,
We are testing RecSync on the following environment.
Linux my.site 3.10.0-1160.41.1.el7.x86_64 #1 SMP Tue Aug 31 08:06:26 CDT 2021 x86_64 x86_64 x86_64 GNU/Linux
python 3.6.8 and twistd 21.7.0.
We have encountered a few issues so far.
  1. Reactor “epoll” is activated by default, and it’s not working.
twistd --reactor=poll -n recceiver -f cf.conf
caused error “reactor is already installed”. Adding code to remove the “epoll” in “__init__.py” fixed the problem. Reactor “poll” is active.
  1. “reactor” does not seem to kick start by itself. Announcer started after “reactor.run()” is added.
  2. The Announcer broadcasted the TCP port with byte-swapped.
Has somebody had similar experience?
Did we miss some important set up procedures?
Any insight is highly appreciated.
Thanks
Jimmy
Prev: RE: error building asyn4-38 : cross_compiler_target_archs=linux-arm 문건영(선형가속기팀) via Tech-talk
Next: Erratic behavior of CS Studio Iain Marcuson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
