I cannot get the Alarm Log Table to show anything. I'm using the default phoebus installation with the Accelerator topic, everything on localhost. Versions: current phoebus from git openJDK 14.0.1 Kafka 2.12-2.4.0, running zk and kafka in separate terminals elasticsearch 6.8.4, this running as a service The kafka and alarm-logger terminals show the alarm events, and the Elasticsearch shows the indices: curl -XGET localhost:9200/_cat/indices/ yellow open accelerator_alarms_cmd_2022-02-01 6fGn4YdqS-OfVnnzYl8-lQ 5 1 3 0 14.4kb 14.4kb yellow open accelerator_alarms_config_2022-02-01 jPrWr4h-SYqr-yiW29W_fw 5 1 77 0 179.5kb 179.5kb yellow open accelerator_alarms_state_2022-02-01 gF3U7_gpQSGf3zilts2nkQ 5 1 3991 0 544.3kb 544.3kb What is suspicious: During maven build there is a complaint about SLF4J: [INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ service-alarm-logger --- [INFO] Building jar: /opt/phoebus/phoebus/services/alarm-logger/target/service-alarm-logger-4.6.6-SNAPSHOT.jar [INFO] [INFO] --- spring-boot-maven-plugin:2.1.6.RELEASE:repackage (default) @ service-alarm-logger --- SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder". SLF4J: Defaulting to no-operation (NOP) logger implementation SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details. [INFO] Replacing main artifact with repackaged archive [INFO] [INFO] --- maven-assembly-plugin:3.2.0:single (make-assembly) @ service-alarm-logger --- Do I need to add a dependency in the alarm-logger pom.xml file to get StaticLoggerBinder to be visible? Regards, -ps
ANJ, 14 Sep 2022 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
