1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Error while installing the StreamDevice
From: ZALA ARYANSINH via Tech-talk <[email protected]>
To: [email protected]
Date: Sat, 19 Feb 2022 14:19:53 +0530
I am getting the following error while using make command for installing the StreamDevice.
make -C ./configure install
make[1]: Entering directory '/home/aryan/EPICS/support/StreamDevice/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/home/aryan/EPICS/support/StreamDevice/configure/O.linux-x86_64'
perl -CSD /home/aryan/EPICS/epics-base/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/home/aryan/EPICS/support/StreamDevice/configure/O.linux-x86_64'
make[1]: Leaving directory '/home/aryan/EPICS/support/StreamDevice/configure'
make -C ./src install
make[1]: Entering directory '/home/aryan/EPICS/support/StreamDevice/src'
make[2]: Entering directory '/home/aryan/EPICS/support/StreamDevice/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux    -DUSE_TYPED_RSET -DSTREAM_INTERNAL   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include          -I/home/aryan/EPICS/epics-base/include/compiler/gcc -I/home/aryan/EPICS/epics-base/include/os/Linux -I/home/aryan/EPICS/epics-base/include        -MM -MF AsynDriverInterface.d  ../AsynDriverInterface.cc
../AsynDriverInterface.cc:37:10: fatal error: asynDriver.h: No such file or directory
   37 | #include "asynDriver.h"
compilation terminated.
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux    -DUSE_TYPED_RSET -DSTREAM_INTERNAL   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include          -I/home/aryan/EPICS/epics-base/include/compiler/gcc -I/home/aryan/EPICS/epics-base/include/os/Linux -I/home/aryan/EPICS/epics-base/include        -c ../AsynDriverInterface.cc
make[2]: *** [/home/aryan/EPICS/epics-base/configure/RULES_BUILD:263: AsynDriverInterface.o] Error 1
make[2]: Leaving directory '/home/aryan/EPICS/support/StreamDevice/src/O.linux-x86_64'
make[1]: *** [/home/aryan/EPICS/epics-base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/aryan/EPICS/support/StreamDevice/src'
make: *** [/home/aryan/EPICS/epics-base/configure/RULES_DIRS:85: src.install] Error 2
please help me with the same
RE: Error while installing the StreamDevice Mark Rivers via Tech-talk
Prev: Re: [External] AW: phoebus alarm-logging UI blank Paul Sichta via Tech-talk
Next: RE: Error while installing the StreamDevice Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: [EXTERNAL] Trying to create softIoc to group alarms in one variable Hartman, Steven via Tech-talk
