| I have an IOC that reads a bunch of system monitor values from an FPGA in a single UDP packet and then pushes the values to a bunch of SCAN=“I/O Intr” records (some ai, some longin). Here’s a fragment of the .db file associate with this: record(ai, "$(P)$(R)EVR:freq") { field(DESC, "EVR recovered clock") field(INP, "@asyn($(PORT), 0x2008, 0)") record(longin, "$(P)$(R)Marble:PIO_") { field(DESC, "Marble port expanders") field(INP, "@asyn($(PORT), 0x2003, 0)")
This all seems to work properly — I see the values updating as they should. The issue is that the asynReport output shows the longin records as disconnected (“KD1” is the PORT in the INP fields of the records shown above, “KD1_CMD” is the UDP/IP port communicating with the FPGA). KD1_CMD multiDevice:No canBlock:Yes autoConnect:No KD1 multiDevice:Yes canBlock:Yes autoConnect:Yes addr 8195 autoConnect Yes enabled Yes connected No exceptionActive No addr 8201 autoConnect Yes enabled Yes connected No exceptionActive No
If I run the asynReport with interest level 1, all the records show up. Here’s the report for the ai record shown above: addr 8200 autoConnect Yes enabled Yes connected Yes exceptionActive No exceptionActive No exceptionUsers 0 exceptionNotifys 0 blocked No
This isn’t a big deal since things do seem to work, but I wonder why this difference between asynInt32 callback handling for ai and longin records.
- RE: AsynInt32 SCAN=I/O Intr response Mark Rivers via Tech-talk
Re: Frequent disconnect and auto-reconnects with Serial ASYN and Stream controlled device Zimoch Dirk (PSI) via Tech-talk
Recsync error Larregui, Julian via Tech-talk
<2022>
2025
2026
Mailbox on MVME6100 Amit Chauhan via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
