1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Regarding an error
From: "Yendell, Gary \(DLSLtd, RAL, LSCI\) via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, ZALA ARYANSINH <[email protected]>
Date: Wed, 2 Mar 2022 11:36:52 +0000
It looks like you have two problems. This
2022/03/02 09:17:16.451 SERIALPORT -1 autoConnect could not connect: /dev/ttyACM0 Can't open  No such file or directory
suggests the given serial port is wrong or the device is not connected.
This
2022/03/02 09:17:16.955732 _main_ Can't find readable file 'arduino.proto' in 'helloWorldIOCApp/Db'
and the next few lines are because it can't find the protocol definitions. Did you create /home/pi/Apps/epics/helloWorldIOC/iocBoot/iochelloWorldIOC/helloWorldIOCApp/Db/arduino.proto with the given code snippet and does it have the correct permissions?
Cheers,
Gary
From: Tech-talk <[email protected]> on behalf of ZALA ARYANSINH via Tech-talk <[email protected]>
Sent: 02 March 2022 04:00
To: [email protected] <[email protected]>
Subject: Regarding an error
Hello,
I am currently following a project from the site mentioned below.
I have successfully done the previous mentioned steps. Also a point to note that i am using a virtual machine as i could not install linux on my desktop.
The error that i am facing is:
#!../../bin/linux-x86/helloWorldIOC
## You may have to change helloWorldIOC to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","iochelloWorldIOC")
epicsEnvSet("TOP","/home/pi/Apps/epics/helloWorldIOC")
epicsEnvSet("ASYN","/usr/local/epics/modules/asyn")
epicsEnvSet("STREAM","/usr/local/epics/modules/stream")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
epicsEnvSet(STREAM_PROTOCOL_PATH,"helloWorldIOCApp/Db")
cd "/home/pi/Apps/epics/helloWorldIOC"
dbLoadDatabase "dbd/helloWorldIOC.dbd"
helloWorldIOC_registerRecordDeviceDriver pdbbase
drvAsynSerialPortConfigure("SERIALPORT","/dev/ttyACM0",0,0,0)
asynSetOption("SERIALPORT",-1,"baud","115200")
asynSetOption("SERIALPORT",-1,"bits","8")
asynSetOption("SERIALPORT",-1,"parity","none")
asynSetOption("SERIALPORT",-1,"stop","1")
asynSetOption("SERIALPORT",-1,"clocal","Y")
asynSetOption("SERIALPORT",-1,"crtscts","N")
dbLoadRecords("db/arduino.db","PORT='SERIALPORT'")
## Load record instances
#dbLoadRecords("db/xxx.db","user=piHost")
cd "/home/pi/Apps/epics/helloWorldIOC/iocBoot/iochelloWorldIOC"
iocInit
Starting iocInit
## EPICS R3.14.12.5 $Date: Tue 2015-03-24 09:57:35 -0500$
## EPICS Base built Feb 21 2022
2022/03/02 09:17:16.955804 _main_ while reading protocol 'get_analog' for 'photo:get'
2022/03/02 09:17:16.955832 _main_ photo:get: Protocol parse error
2022/03/02 09:17:16.955858 _main_ photo:get: Record initialization failed
2022/03/02 09:17:16.955919 _main_ Can't find readable file 'arduino.proto' in 'helloWorldIOCApp/Db'
2022/03/02 09:17:16.955950 _main_ while reading protocol 'set_digital' for 'led:set'
2022/03/02 09:17:16.955979 _main_ led:set: Protocol parse error
2022/03/02 09:17:16.956005 _main_ led:set: Record initialization failed
Bad init_rec return value  PV: led:set ao: init_record
## Start any sequence programs
#seq sncxxx,"user=piHost"
epics> 2022/03/02 09:17:17.960955 scan0.5 photo:get: Record not initialised correctly
2022/03/02 09:17:18.457259 scan0.5 photo:get: Record not initialised correctly
2022/03/02 09:17:18.957321 scan0.5 photo:get: Record not initialised correctly
Re: Regarding an error Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Regarding an error ZALA ARYANSINH via Tech-talk
Prev: Archiver Appliance Wrong last event timestamp Abdalla Ahmad via Tech-talk
Next: Re: Regarding an error Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Regarding an error ZALA ARYANSINH via Tech-talk
