1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Timing in seq record
Date: Thu, 3 Mar 2022 00:30:36 +0000
I have the following simple database with a seq record which just writes 1 and 0 to the Shutter record.  There is a delay of $(DELAY) before writing 1 and before writing 0.
record(seq,"$(P)OpenCloseShutter") {
    field(PINI, "YES")
    field(DLY0,"$(DELAY)")
    field(DOL0,"1")
    field(LNK0,"$(P)Shutter PP MS")
    field(DLY1,"$(DELAY)")
    field(DOL1,"0")
    field(LNK1,"$(P)Shutter PP MS")
    field(FLNK,"$(P)OpenCloseShutter.PROC CA")
record(bo, "$(P)Shutter") {
    field(ZNAM, "Done")
    field(ONAM, "Moving")
If DELAY is 0.1 I see the following with camonitor on Shutter:
Test:Shutter                   2022-03-02 18:22:24.997849 Moving
Test:Shutter                   2022-03-02 18:22:25.092984 Done
Test:Shutter                   2022-03-02 18:22:25.188102 Moving
Test:Shutter                   2022-03-02 18:22:25.283205 Done
Test:Shutter                   2022-03-02 18:22:25.378332 Moving
Test:Shutter                   2022-03-02 18:22:25.473436 Done
Test:Shutter                   2022-03-02 18:22:25.568547 Moving
Test:Shutter                   2022-03-02 18:22:25.663681 Done
Test:Shutter                   2022-03-02 18:22:25.758885 Moving
Test:Shutter                   2022-03-02 18:22:25.854026 Done
Test:Shutter                   2022-03-02 18:22:25.949228 Moving
The period is about 190 ms rather than the expected 200 ms, but not too far off.
However, if I set DELAY=0.01 then I see this:
Test:Shutter                   2022-03-02 18:25:44.341923 Done
Test:Shutter                   2022-03-02 18:25:44.347055 Moving
Test:Shutter                   2022-03-02 18:25:44.352186 Done
Test:Shutter                   2022-03-02 18:25:44.357367 Moving
Test:Shutter                   2022-03-02 18:25:44.362523 Done
Test:Shutter                   2022-03-02 18:25:44.367682 Moving
Test:Shutter                   2022-03-02 18:25:44.372816 Done
Test:Shutter                   2022-03-02 18:25:44.377965 Moving
Test:Shutter                   2022-03-02 18:25:44.383104 Done
Test:Shutter                   2022-03-02 18:25:44.388263 Moving
Test:Shutter                   2022-03-02 18:25:44.393372 Done
Test:Shutter                   2022-03-02 18:25:44.398496 Moving
Test:Shutter                   2022-03-02 18:25:44.403633 Done
The period is 10 ms when it should be 20 ms.  The DELAY appears to be 5 ms, not 10 ms.
If I set DELAY=.005 then the Shutter PV has no monitor events.
Something seems wrong here, since I know that epicsThreadSleep on Linux is capable of good accuracy down to 100 microseconds or so.
This is base 7.0.4 on Centos 7.  Is this expected?
RE: Timing in seq record Mark Rivers via Tech-talk
Prev: Re: Archiver Appliance Wrong last event timestamp Shankar, Murali via Tech-talk
Next: RE: Timing in seq record Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: loc vs sim in Phoebus Mogamat Amien Crombie via Tech-talk
