Subject: |
Re: strange error Pop up error in win10 epics |
Ralph Lange via Tech-talk <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Fri, 4 Mar 2022 11:44:57 +0100 |
Hi, I have a question about epics in Win10(64). I installed base 7.0.6.1 in win10 successfully. Then I created an example named example1 using makeBaseApp.pl. When I executed the example1.exe, I got these error(it is a pop up error): ( i try to use the cmd command D:\windowsEpics\firstExample\bin\windows-x64-mingw\example1.exe st.cmd and try to double click example1.exe ,same error came out )
Hello Lynn,
Assuming you followed the Windows instructions at
Which choices for environment, compilation, linking, and deployment did you make?
Cheers, ~Ralph
- strange error Pop up error in win10 epics 网易邮件中心 via Tech-talk
Develop motor drivers using controller's DLL 岳宗仰 via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
