1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Linking PVs to EGU field
From: "Runchey, John via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, "Marco A. Barra Montevechi Filho" <marco.filho at lnls.br>
Date: Mon, 14 Mar 2022 18:35:18 +0000
There may well be a better way to do it, but this does work, using a stringout record as an intermediary:
record(mbbi, "PressureUnit") {
  field(DESC, "Vacuum measurement unit")
  field(PINI, "YES")
  field(SCAN, "Passive")
  field(NOBT, "2")
  field(ZRVL, "0")
  field(ZRST, "mbar")
  field(ONVL, "1")
  field(ONST, "Pa")
  field(THVL, "2")
  field(THST, "Torr")
  field(FLNK, "sendUnit")
record(stringout, "sendUnit") {
  field(DOL, "PressureUnit")
  field(OMSL, "closed_loop")
  field(OUT, "_Pressure.EGU")
record(ai, "_Pressure") {
  field(DESC, "Get device pressure")
  field(PINI, "YES")
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, March 14, 2022 12:30 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Linking PVs to EGU field
Hello all.
I have an IOC that controls a mvc3 pressure gauge controller and retrieves its information. Between many PVs, the IOC has one that is responsible for taking the pressure values and one that is responsible for taking the units in which these pressures are expressed. Both use the stream module to send commands to the gauge and retrieve its response. I want to make the units end up automatically in the _Pressure.EGU field, but i dont know how.
I've tried:
record(mbbi, "$(BEAMLINE):$(DEVICE_NAME):PressureUnit") {
  field(PINI, "YES")
  field(DTYP, "stream")
  field(NOBT, "2")
  field(ZRVL, "0")
  field(ZRST, "mbar")
  field(ONVL, "1")
  field(ONST, "Pa")
  field(THVL, "2")
  field(THST, "Torr")
  field(INP, "@mvc3.proto PressureUnit $(PORT)")
record(ai, "$(BEAMLINE):$(DEVICE_NAME):_Pressure") {
  field(EGU, "$(BEAMLINE):$(DEVICE_NAME):PressureUnit")
  field(PINI, "YES")
  field(SCAN, "1 second")
  field(INP, "@mvc3.proto RPV$(CHAN_NUM) $(PORT)")
But, although cagets to PressureUnit and to _Pressure do return their values, any call to $(BEAMLINE):$(DEVICE_NAME):_Pressure.EGU returns no actual value.
Are there any suggestions? I also tried FLNK or DOL but im not sure if im using them correctly. Thanks in advance.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Linking PVs to EGU field Marco A. Barra Montevechi Filho via Tech-talk
Prev: Linking PVs to EGU field Marco A. Barra Montevechi Filho via Tech-talk
Next: StripTool license file Thomas, Patrick via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Re: Linking PVs to EGU field Ralph Lange via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
