1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: odd ASYN behavior
To: "[email protected]" <[email protected]>, "Runchey, John" <[email protected]>
Date: Fri, 18 Mar 2022 18:16:21 +0000
Hi John,
I just tested with my TetrAmm and I cannot reproduce the behavior you are seeing.  As soon as I change AcquireMode then AcquireMode_RBV also changes.  Actually AcquireMode_RBV changes about 10-20 microseconds before AcquireMode.  Here is the output from camonitor:
corvette:~>camonitor 13IDA:QE1:AcquireMode 13IDA:QE1:AcquireMode_RBV
13IDA:QE1:AcquireMode          2022-02-01 10:07:24.187031 Continuous WRITE INVALID
13IDA:QE1:AcquireMode_RBV      2022-02-01 10:07:24.187028 Continuous
13IDA:QE1:AcquireMode_RBV      2022-03-18 13:06:48.532124 Single
13IDA:QE1:AcquireMode          2022-03-18 13:06:48.582639 Single
13IDA:QE1:AcquireMode_RBV      2022-03-18 13:06:53.401958 Multiple
13IDA:QE1:AcquireMode          2022-03-18 13:06:53.401969 Multiple
13IDA:QE1:AcquireMode_RBV      2022-03-18 13:06:58.066979 Continuous
13IDA:QE1:AcquireMode          2022-03-18 13:06:58.066999 Continuous
13IDA:QE1:AcquireMode_RBV      2022-03-18 13:07:12.250304 Single
13IDA:QE1:AcquireMode          2022-03-18 13:07:12.278290 Single
13IDA:QE1:AcquireMode_RBV      2022-03-18 13:07:22.147686 Multiple
13IDA:QE1:AcquireMode          2022-03-18 13:07:22.147697 Multiple
13IDA:QE1:AcquireMode_RBV      2022-03-18 13:07:27.644870 Continuous
13IDA:QE1:AcquireMode          2022-03-18 13:07:27.644886 Continuous
Please send a screen shot of your quadEM.adl screen when you have the issue and we can see if there is some difference in your settings from mine that could be causing the problem.
Sent: Friday, March 18, 2022 12:45 PM
To: [email protected] <[email protected]>; Runchey, John <[email protected]>
HI John,
I just looked at the code in drvQuadEM::writeInt32 and drvTetrAMM::setAcquireMode and it looks OK.  It sets the new value in the parameter library at the beginning and unconditionally does callParamCallbacks at the end.  That should result in the camonitor value being correct.
I am on vacation but will test this when I return.  Meanwhile you could enable all of the asynTrace debugging to see what that shows.
From: Tech-talk <[email protected]> on behalf of Runchey, John via Tech-talk <[email protected]>
Sent: Monday, March 14, 2022 11:14 AM
Subject: odd ASYN behavior
I'm working with a new build of QUADEM for the tetrAMM and seeing a weird asyn issue.
Summary: When writing to the AcquireMode PV, the associated _RBV PV is 'one behind' in reporting the new value, consistently. But if I manually do a caput to the _RBV.PROC field and force it to process, the readback is then consistently correct.
camonitor of the issue:
S28IDFE-XBPM:CM3ds:AcquireMode 03/11/22 09:00:39.158459244 Single
S28IDFE-XBPM:CM3ds:AcquireMode_RBV 03/11/22 09:00:39.158436082 Multiple
S28IDFE-XBPM:CM3ds:AcquireMode_RBV 03/11/22 09:01:23.572226245 Single
S28IDFE-XBPM:CM3ds:AcquireMode 03/11/22 09:01:23.572245721 Continuous
S28IDFE-XBPM:CM3ds:AcquireMode_RBV 03/11/22 09:01:34.876944669 Continuous
S28IDFE-XBPM:CM3ds:AcquireMode 03/11/22 09:01:34.876973666 Multiple
after caput AcquireMode_RBV.PROC 1:
S28IDFE-XBPM:CM3ds:AcquireMode_RBV 03/11/22 09:06:33.097901171 Single
// caput caused _RBV to update to the (correct) value of Continuous
S28IDFE-XBPM:CM3ds:AcquireMode_RBV 03/11/22 09:06:42.683848695 Continuous
S28IDFE-XBPM:CM3ds:AcquireMode 03/11/22 09:06:42.683874661 Continuous
S28IDFE-XBPM:CM3ds:AcquireMode_RBV 03/11/22 09:06:44.284941724 Multiple
S28IDFE-XBPM:CM3ds:AcquireMode 03/11/22 09:06:44.284974097 Multiple
S28IDFE-XBPM:CM3ds:AcquireMode_RBV 03/11/22 09:06:45.876836770 Single
S28IDFE-XBPM:CM3ds:AcquireMode 03/11/22 09:06:45.876854823 Single
This is the first time I've built this on a RHEL 8 machine for what that's worth.
Any thoughts?
John
Re: odd ASYN behavior Runchey, John via Tech-talk
Re: odd ASYN behavior Mark Rivers via Tech-talk
Prev: Re: odd ASYN behavior Mark Rivers via Tech-talk
Next: Re: odd ASYN behavior Runchey, John via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
