1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Timestamp test questions on Linux
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: gjzhai at mail.ustc.edu.cn
Cc: tech-talk at aps.anl.gov
Date: Fri, 18 Mar 2022 20:27:46 -0500
On 3/17/22 19:01, gjzhai at mail.ustc.edu.cn wrote:
The R&S®SMB100A microwave signal generator outputs 1Hz pulses to the EVG. I select the source of event 125 from front panel input 0.
What you describe is exactly what I would expect if the ~1Hz signal originates
from a free running oscillator which is different to that used for the system
clock.
Unless your signal generator and system clock are ultimately derived from, or
synchronized to, the same reference oscillator (eg. GPS or similar) one will
always drift with respect to the other.
What is usually done is to have a GPS receiver with both an electrical 1Hz
output (often called Pulse Per Second), and a logical connection to an NTP
server.  Devices like this are available from multiple vendors.  Some
examples (which I don't specifically endorse):
https://www.meinbergglobal.com/english/productinfo/gps-time-server.htm
https://www.microsemi.com/product-directory/synchronization-systems/3818-enterprise-network-time-servers
https://endruntechnologies.com/products/ntp-time-servers/ntp-server
epics> dbpf("TST{evg:1-TrigEvt:0}TrigSrc-Sel","Front0")
DBR_STRING:          "Front0"
epics> dbpf("TST{evg:1}1ppsInp-Sel","1")
epics> dbpf("TST{evg:1}1ppsInp-MbbiDir_.TPRO","1")
DBR_UCHAR:          1         0x1
-----原始邮件-----
发件人: "Michael Davidsaver" <mdavidsaver at gmail.com>
发送时间: 2022-03-09 15:05:05 (星期三)
收件人: gjzhai at mail.ustc.edu.cn
抄送: tech-talk at aps.anl.gov
主题: Re: Timestamp test questions on Linux
On 3/7/22 00:47, gjzhai--- via Tech-talk wrote:
Hello!
I installed mrfioc2 2.3.0 on MTCA platform. According to EVR Usage Guide, when I do the timestamp test, there are two problems:
Could you describe your setup in more detail?
Where does the 1Hz (aka. 1 pulse per second) signal to the EVG
originate?  The same GPS receiver as the NTP server in question?
https://github.com/epics-modules/mrfioc2/blob/a8cb48d549b7aae13206cf2d168c6f1cfec2e1c4/evgMrmApp/Db/evgMrm.db#L93
a. The system is configured with NTP, but the current time provider does not have NTP
[opi@localhost ~]$ ntpstat
synchronised to NTP server (202.38.64.7) at stratum 3
     time correct to within 11 ms
     polling server every 512 s
b. The time interval between the system clock and the EVR time is large.
epics> generalTimeReport(2) Backwards time errors prevented 446106 times. Current Time Providers: "EVR", priority = 50 Current Time is 2022-03-07 16:34:25.575015. "OS Clock", priority = 999 Current Time is 2022-03-07 16:36:55.978638. Event Time Providers: "EVR", priority = 50
Thank you for your time. I am looking forward to your reply.
Timestamp test questions on Linux gjzhai--- via Tech-talk
Re: Timestamp test questions on Linux Michael Davidsaver via Tech-talk
Re: Timestamp test questions on Linux gjzhai--- via Tech-talk
Prev: Re: Epics Archiver Appliance and Network Storage slowdown Michael Davidsaver via Tech-talk
Next: RE: Epics Archiver Appliance and Network Storage slowdown Zhang, Tong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: Timestamp test questions on Linux gjzhai--- via Tech-talk
Next: RE: Tech-talk Digest, Vol 16, Issue 101 Rebecca Harding - STFC UKRI via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
