1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: Only one network interface of three NF CA5351 Current Amplifiers is accessible
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Chiang, Liang-Chih [江良志] <chiang.lc at nsrrc.org.tw>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 22 Mar 2022 15:24:28 +0000
Can you give some more information:
-          Have you configured these for static IP addresses or DHCP?
-          When you say “accessible” how are you defining this?  Have you tried pinging all 3 devices when only 1 is “accessible”?
-          You can get it into a state where “everything is fine”.  What do you need to do to get back to the bad state?
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Chiang, Liang-Chih [???] via Tech-talk
Sent: Monday, March 21, 2022 10:53 PM
To: tech-talk at aps.anl.gov
Subject: Only one network interface of three NF CA5351 Current Amplifiers is accessible
Hello,
I have three NF CA5351 Current Amplifiers and use Ethernet/LAN to access them remotely.
(product webpage: https://www.nfcorp.co.jp/english/pro/mi/loc/pre/ca5351/index.html  )
For some reason which I don't know, they would behave erroneously.
Only one of them is accessible remotely, and after several seconds, the accessible one will change.
That is,
only no. 1 is accessible,
 several seconds passed,
only no. 2 is accessible,
only no. 3 is accessible,
...repeat the above sequence...
I try rebooting the devices, doesn't work.
The solution I found is:
Unplug the network cable,
change the IP address of the device,
change the IP address back to the original setting,
plug the network cable.
Then everything is fine.
Does anyone have any idea about this bizarre behavior?
Best regards.
LiangChih Chiang
NSRRC Beamline group
email: chiang.lc at nsrrc.org.tw
回覆: Only one network interface of three NF CA5351 Current Amplifiers is accessible Chiang, Liang-Chih [江良志] via Tech-talk
Prev: Re: NDCodec Compression Factor Mark Rivers via Tech-talk
Next: 回覆: Only one network interface of three NF CA5351 Current Amplifiers is accessible Chiang, Liang-Chih [江良志] via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Only one network interface of three NF CA5351 Current Amplifiers is accessible Chiang, Liang-Chih [江良志] via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
