Dear EPICS experts,
I'm trying to add Portable Channel Access Server (libcas) to an existing
application. The main part of work is straightforward, thanks to "Channel
Access Portable Server Application Interface (API) Tutorial" at
https://epics.anl.gov/extensions/cas/CAS_Tutorial.pdf
and "Channel Access Portable Server: Reference Guide" at
https://epics.anl.gov/extensions/cas/CAS_Reference.pdf
However, I can't find a way to integrate libcas file descriptor
management (which is implemented by fdManager) with application's native
main loop (which is select()-based). The only recipe I found is to call
fileDescriptorManager.process() periodically.
The question is: do fdManager/libcas include a functionality similar to
CA's ca_add_fd_registration(), for it to be able to register its file
descriptors directly with application's main loop?
(And, probably, a similar API for timeouts?)
Or is periodic calling fileDescriptorManager.process(0) the only way?
RE: Epics Archiver Appliance and Network Storage slowdown Manoussakis, Adamandios via Tech-talk
Re: About checksum error Mark Rivers via Tech-talk
<2022>
2025
RE: cross-compiling Base 7.0.6 for win32 Daykin, Evan via Tech-talk
ADViewer, EPICS_NTNDA_Viewer.java compilation Tomasz Brys via Tech-talk
<2022>
2025
