1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: ADViewer, EPICS_NTNDA_Viewer.java compilation
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, Tomasz Brys <Tomasz.Brys at ess.eu>
Date: Fri, 25 Mar 2022 15:05:19 +0000
Hi Tomasz,
I am a Java novice, but I got the compilation to almost work by running in the ImageJplugins/EPICS_areaDetector directory:
corvette:ImageJ/plugins/EPICS_areaDetector>java -cp jca-2.4.5.jar:epics-ntypes-0.3.5.jar:epics-pvaccess-5.1.5.jar:epics-pvdata-6.1.5.jar:epics-pvaclient-4.3.2.jar:epics-util-1.0.3.jar:../../ij.jar EPICS_NTNDA_Viewer.java
EPICS_NTNDA_Viewer.java:112: error: cannot find symbol
    private NTNDCodec ntndCodec = null;
  symbol:   class NTNDCodec
EPICS_NTNDA_Viewer.java:408: error: cannot find symbol
                ntndCodec = new NTNDCodec();
2 errors
error: compilation failed
It is only complaining that it can't find NTNDCodec.  That is also provide as source code, NTNDCodec.java.  When I try to compile that I get this error:
corvette:ImageJ/plugins/EPICS_areaDetector>java -cp jca-2.4.5.jar:epics-ntypes-0.3.5.jar:epics-pvaccess-5.1.5.jar:epics-pvdata-6.1.5.jar:epics-pvaclient-4.3.2.jar:epics-util-1.0.3.jar:../../ij.jar NTNDCodec.java
NTNDCodec.java:29: error: package com.sun.jna does not exist
import com.sun.jna.NativeLong;
I don't remember how to fix that, but it is probably straightforward.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Tomasz Brys via Tech-talk <tech-talk at aps.anl.gov>
Sent: Friday, March 25, 2022 9:24 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: ADViewer, EPICS_NTNDA_Viewer.java compilation
I want to compile EPICS_NTNDA_Viewer.java from the command line. I need it for my script which will automatize all the installation process of the areaDetector.
For the EPICS_AD_Viewer.java I simply used this command:
javac -cp ~/.imagej/plugins/jca-2.4.5.jar:/usr/share/java/ij.jar  ~/.imagej/plugins/EPICS_AD_Viewer.java
and plugin appears in imageJ.
I tried to do the same with NTNDA_Viewer by:
javac -cp ~/.imagej/plugins/jca-2.4.5.jar:/usr/share/java/ij.jar  ~/.imagej/plugins/EPICS_NTNDA_Viewer.java
but this doesn’t work. It complains for missing packages: pvaClient, pvdata etc.
I tried to put all of them in the command line but I did not succeed.
Can somebody help me with compilation of it?
/Tomasz Brys
BTW it works when I compile it from imageJ GUI but I want to do it from the command line.
Re: ADViewer, EPICS_NTNDA_Viewer.java compilation J. Lewis Muir via Tech-talk
ADViewer, EPICS_NTNDA_Viewer.java compilation Tomasz Brys via Tech-talk
Prev: ADViewer, EPICS_NTNDA_Viewer.java compilation Tomasz Brys via Tech-talk
Next: Re: ADViewer, EPICS_NTNDA_Viewer.java compilation J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
