1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: [EXTERNAL] phoebus 4.6.6 in windows can't start editor
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, "Lee L. Yang" <llyang at lbl.gov>
Date: Fri, 25 Mar 2022 16:30:32 +0000
Hi:
> I downloaded windows version of phoebus 4.6.6 from
> hxxps://controlssoftware.sns.ornl.gov/css_phoebus/
> The display editor wouldn't start, saying:
> "Missing user rights to run Display Editor. The application cannot be started".
The more interesting version info is in the Help/About dialog, which should say something like
"master 2022-03-25" to show the git branch and build date.
Using a download from right now, I cannot duplicate the issue. Editor opens fine.
There _is_ a preference/authorization setting for opening the editor, which should default to allowing anybody to open the editor, see https://control-system-studio.readthedocs.io/en/latest/authorization.html and the current default settings https://github.com/ControlSystemStudio/phoebus/blob/master/core/security/src/main/resources/authorization.conf
In case you configured site-specific authorization settings, you need to add this to your authorization.conf
# Anybody can run Display Editor
edit_display = .*
Or start over with default settings by deleting the .phoebus folder in your home dir.
-Kay
phoebus 4.6.6 in windows can't start editor Lee L. Yang via Tech-talk
Prev: phoebus 4.6.6 in windows can't start editor Lee L. Yang via Tech-talk
Next: Re: About checksum error Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Modbus module duplicating definitions Marco A. Barra Montevechi Filho via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
