Hallo Kevin,
thank You for the help to understand what happens in the motorRecord,
nasty beast this record!
The homing type is here on the positive end-switch "Mn.m+". Poll period
0.5s but ACCL=2.0
There was a bug in the phyMotion software if you use the positive
end-switch, but there is an update from phytron and now it works if you
give this command by the phyLogic software.
Ok, You say the record recognises a motor action to be done by
pC_->motorStatusDone_ This is set in the poll routine by the command
"Mn.m==H". In the log you can see that there is no "M1.1==H" with the
answer "E" for done after hitting the end-switch and before the new move
comand occurs. So we suppose a problem in the record.
By the way, we have a support for the phytron IO modules. There I
introduced support for stringout -in Record to communicate with the
motor controller. If you send a home command this way, it works as expected.
Bernhard
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
- Re: motorRecord with phytron support: record send goto 0 command before reference is done Torsten Bögershausen via Tech-talk
- Re: motorRecord with phytron support: record send goto 0 command before reference is done Kevin Peterson via Tech-talk
- motorRecord with phytron support: record send goto 0 command before reference is done Bernhard Kuner via Tech-talk
fanout Dominik Domagała via Tech-talk
Re: fanout Paul Sichta via Tech-talk
<2022>
2025
<2022>
2025
