1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: fanout
From: Andrew Johnson via Tech-talk <tech-talk at aps.anl.gov>
To: Paul Sichta <psichta at pppl.gov>, Dominik Domagała <Dominik.Domagala at s2innovation.com>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 29 Mar 2022 12:58:39 -0500
On 3/29/22 11:53 AM, Paul Sichta via Tech-talk wrote:
Note that the fanout record is  used to send FWDLINKs to cause other (passive) records to process.  The dfanout record is used to fanout a data value to put into other records. The dfanout record has no selection mechanism .
Actually that last part is no longer true, since Base-3.14 the dfanout record has supported the same SELM/SELN/SELL fields as the fanout record, see its record reference page for details. The latest version of the fanout record also now supports 16 output links, whereas the dfanout still only has 8. If you need more, take a look at the sequence record which has 16 inputs and outputs and is somewhat more complex but can be configured to do the same things and more.
- Andrew
On Tue, Mar 29, 2022 at 10:28 AM Dominik Domagała via Tech-talk <tech-talk at aps.anl.gov> wrote:
Dear All,
I would like to ask about using fanout record. I have to send by fanout values only for dynamically chosen outputs.
One idea is to use SELM_mask. Can anybody share any example with using dynamically changed mask? Even with using fanoutSELM_mask.
Pozdrawiam serdecznie/Best Regards/Mit Freundlichen Grüßen/Med vänliga hälsningar/Lep pozdrav
Dominik Domagała
S2INNOVATION Sp. z o. o.
tel.: +48 502 131 026
ul. Podole 60, 30-394 Kraków, PL
NIP: 676 254 14 01, REGON: 36896840000000
Sąd rejonowy dla Krakowa-Śródmieścia w Krakowie, XI Wydział Gospodarczy Krajowego Rejestru Sądowego,
Numer KRS: 0000709081, Kapitał zakładowy: 10 250 PLN.
Wiadomość ta jest przeznaczona jedynie dla osoby lub podmiotu będącego jej adresatem i może zawierać informacje stanowiące tajemnicę przedsiębiorstwa. Zabronione jest przeglądanie, przesyłanie, rozpowszechnianie, wykorzystywanie tych informacji, lub podejmowanie działań na ich podstawie, przez osoby lub podmioty inne niż zamierzony adresat.  Niestosowanie się do tego zakazu grozi odpowiedzialnością prawną. Jeśli otrzymali Państwo tę wiadomość przez pomyłkę, prosimy o poinformowanie nadawcy i usunięcie jej niezwłocznie z komputera.
Administratorem Pani/Pana danych osobowych, w tym danych adresowych oraz adresu email jest S2Innovation sp. z o.o. Z Administratorem można się kontaktować pisemnie, za pomocą poczty tradycyjnej pod adresem: ul. Podole 60, 30-394 Kraków lub poprzez e-mail: contact at s2innovation.com.
Administrator będzie przetwarzał dane osobowe w celu utrzymania niezbędnego kontaktu, udzielania odpowiedzi na zapytania, a także w celu zawarcia i realizacji umowy z S2Innovation sp. z o.o.
Szczegółowe informacje dotyczące przetwarzania danych osobowych w naszej firmie znajdziesz na naszej stronie internetowej w zakładce Ochrona danych osobowych/RODO.
Complexity is free, it's Simplicity that takes work.
fanout Dominik Domagała via Tech-talk
Re: fanout Paul Sichta via Tech-talk
Prev: Re: fanout Daykin, Evan via Tech-talk
Next: Re: motorRecord with phytron support: record send goto 0 command before reference is done Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: fanout Paul Sichta via Tech-talk
Next: Re: fanout Daykin, Evan via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
