1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Static Build on armv7
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: Florian Feldbauer <florian at ep1.ruhr-uni-bochum.de>
Cc: tech-talk at aps.anl.gov
Date: Wed, 30 Mar 2022 08:47:11 -0700
On 3/30/22 07:15, Florian Feldbauer via Tech-talk wrote:
Hey all,
we use docker images to easily deploy our IOCs for our detector control system.
The images are build for amd64, arm64/aarch64 and armv7.
To reduce the size of those images, I recently switched from dynamic to static linking by adding the line
 >      && echo "STATIC_BUILD=YES" >> configure/CONFIG_SITE.local \
to our Dockerfile.
When compiling base7 for amd64 and aarch64 this is working just fine, but I get an error on arm/v7:
#0 189.7 Installing created executable /epics/base/bin/linux-arm/antelope
#0 190.1 /epics/base/bin/linux-arm/antelope -bparse -l -d ../flex/parse.y
#0 190.1 /usr/lib/ld.so.1: No such file or directory
#0 198.7 Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
I investigated the issue a bit closer and found the following:
root@195e454a8580:/epics/src/base# ldd /epics/base/bin/linux-arm/antelope
  linux-vdso.so.1 (0x7ef10000)
  libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0x76e71000)
  /usr/lib/ld.so.1 => /lib/ld-linux-armhf.so.3 (0x76f70000)
It looks like "STATIC_BUILD=YES" was ignored.
root@195e454a8580:/epics/src/base# ls /usr/lib/ld.so.1
ls: cannot access '/usr/lib/ld.so.1': No such file or directory
For some reason antelope gets linked against /usr/lib/ld.so.1 on armv7 but this file does not exist.
Does anyone know what causes this issue?
It would help if you could attach, or post somewhat, the complete
output of a clean 'make'.
Also the output of:
readelf -aW /epics/base/bin/linux-arm/antelope
Cheers,
Florian
Re: Static Build on armv7 Florian Feldbauer via Tech-talk
Prev: Static Build on armv7 Florian Feldbauer via Tech-talk
Next: Re: softIoc compiling-in relative path to softIoc.dbd Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Re: Static Build on armv7 Florian Feldbauer via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
