1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: asyn trace masks on modbus reconnect
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: John Dobbins <john.dobbins at cornell.edu>
Cc: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
Date: Fri, 1 Apr 2022 03:43:31 +0000
Hi John,
> Am I correct in assuming that if this was because the IOC lost its connection to the plc, this would be reported as an error in the IOC console [asynTraceMask is not explicitly set so it is the default value of 1?]
Yes.  Starting in Modbus R2-17 (September 2017) each Modbus asyn port driver prints a single error message when a read operation from the PLC returns an error, and a single message when a read operation succeeds again.
Here is an example from when we were having some network issues recently:
[Tue Dec 21 12:06:01 2021] 2021/12/21 12:06:00.927 drvModbusAsyn::doModbusIO port K1_Yn_In_Bit error calling writeRead, error=164.54.160.197:502 read error: S_errno_EWOULDBLOCK, nwrite=6/6, nread=0
[Tue Dec 21 12:06:01 2021] 2021/12/21 12:06:01.027 drvModbusAsyn::doModbusIO port K1_Yn_In_Bit writeRead status back to normal having had 1 errors, nwrite=6/6, nread=6
Sent: Thursday, March 31, 2022 7:54 PM
To: Mark Rivers <rivers at cars.uchicago.edu>; Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
No documentation directory but if I look at modbusInterpose.c I see that it matches commits up to June 28,2019 which would make it 3-0 !
Sent: Thursday, March 31, 2022 8:33 PM
To: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
Cc: John Dobbins <john.dobbins at cornell.edu>
If ii is older look in release notes in  documentation directory.
Sent from my iPhone
On Mar 31, 2022, at 7:24 PM, Mark Rivers via Tech-talk <tech-talk at aps.anl.gov> wrote:
 Look at the RELEASE.md in the top level directory.
Sent from my iPhone
On Mar 31, 2022, at 7:18 PM, John Dobbins <john.dobbins at cornell.edu> wrote:
Funny you should ask.  I am looking at this IOC built by someone else and modbus is installed with no obvious version label. Any easy well to tell?
John
Sent: Thursday, March 31, 2022 8:11 PM
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
What version of the Modbus module?
Sent from my iPhone
On Mar 31, 2022, at 6:57 PM, John Dobbins via Tech-talk <tech-talk at aps.anl.gov> wrote:
All,
We have  a WAGO plc which we read via modbus. There are just 18 PVs in this IOC, read as two blocks from the plc. All the PVs briefly go invalid for ~ 5 seconds (as reported by clients like Alarm Server, Archive Appliance)
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
asyn trace masks on modbus reconnect John Dobbins via Tech-talk
Re: asyn trace masks on modbus reconnect Mark Rivers via Tech-talk
Re: asyn trace masks on modbus reconnect John Dobbins via Tech-talk
Prev: Re: asyn trace masks on modbus reconnect John Dobbins via Tech-talk
Next: Job opportunity at CEA Saclay LOTRUS Paul via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
