1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: Compatibility of motor record with submodules
To: Jong Woo Kim <[email protected]>
Date: Wed, 6 Apr 2022 21:54:20 +0000
Hi Jong,
You are using asyn R4-38 and are worried because motor R7-2 says it needs asyn R4-37.
This is not a problem.  We try hard to maintain backwards compatibility in asyn releases, so it is safe to use a newer release.  Newer releases are recommended, since more bugs are fixed.  If a release breaks backward compatibility then that is discussed in the release notes.
From: Tech-talk <[email protected]> On Behalf Of Jong Woo Kim via Tech-talk
Sent: Wednesday, April 6, 2022 1:20 PM
To: [email protected]
Subject: Compatibility of motor record with submodules
Hello,
We are planning to install and build motor record for PI C-887.
According to the above website, R7-1 requires the following submodules.
Asyn R4-35
IPAC R2-15
LUA R1-3
MODBUS R2-11
The following is our EPICS info.
base-3.15.6; SynApps-6-1; motor-R7-1
Asyn R4-38
IPAC R2-15
LUA R2-0
MODBUS R3-0
I am worried about the compatibility issue.
What about installation of R7-2? because required submodules are the same as ours except Asyn.
motor-R7-2 requires
Asyn R4-37
IPAC R2-15
LUA R2-0
MODBUS R3-0
Best,
Jong
Compatibility of motor record with submodules Jong Woo Kim via Tech-talk
Prev: RE: synApps_6_1 and base_7.0.6.1 Mark Rivers via Tech-talk
Next: Driver for Symetrie hexapods? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Compatibility of motor record with submodules Jong Woo Kim via Tech-talk
