1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Can't properly restrict IOC CA server to an interface
From: Jure Varlec via Tech-talk <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Fri, 15 Apr 2022 09:12:22 +0000
> As I recall, I've gotten myself into trouble while playing with
> bridging and tunneling when both ends of the tunnel, or two taps
> on the bridge, were on the same host.
> Beyond this, wrt. understanding routing in the Linux IP stack, all I can
> do is mention "ip route get <dest>", and assure you that however confused
> you are now, it would be worse with IPv6.
> some random notes after a frustrating afternoon...
Yes, it's the stuff of nightmares. Thanks for the notes, much appreciated.
As for my problem, it's reproducible with netcat. Moreover, it's reproducible
with the bridge that the docker service sets up as well. I guess it's just
something about bridges, and while it irks me that I don't understand it,
can't go dig deeper right now. I guess I'll have to figure out a different
topology for this network ...
Thanks!
Jure
Can't properly restrict IOC CA server to an interface Jure Varlec via Tech-talk
Re: Can't properly restrict IOC CA server to an interface Michael Davidsaver via Tech-talk
Re: Can't properly restrict IOC CA server to an interface Jure Varlec via Tech-talk
Prev: Re: Driver for Symetrie hexapods? Torsten Bögershausen via Tech-talk
Next: drvModbusAsynConfigure exception 3 when ASLO and PREC fields of PV are changed Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Can't properly restrict IOC CA server to an interface Michael Davidsaver via Tech-talk
Next: phoebus: write waveform PV William Kirstaedter via Tech-talk
