1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Waveforms in Archiver Appliance
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: John Dobbins <john.dobbins at cornell.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 21 Apr 2022 09:23:19 -0700
On 4/21/22 09:14, John Dobbins wrote:
Michael ,
It turned out to be the array size/EPICS_CA_MAX_ARRAY_BYTES.
Was this in the IOC or Archiver?
fyi. Base >= 3.16.1 doesn't use EPICS_CA_MAX_ARRAY_BYTES any more (by default).
https://github.com/epics-base/epics-base/blob/7.0/documentation/RELEASE_NOTES.md#epics_ca_max_array_bytes-is-optional
   I was only putting 50 values in the array but NELM =2048. Reducing NELM fixed the problem.
Also, thanks for the pointer to the policies info. I was wondering about that.
John
*From:* Michael Davidsaver <mdavidsaver at gmail.com>
*Sent:* Thursday, April 21, 2022 12:07 PM
*To:* John Dobbins <john.dobbins at cornell.edu>
*Cc:* tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
*Subject:* Re: Waveforms in Archiver Appliance
On 4/21/22 06:47, John Dobbins via Tech-talk wrote:
All,
Does the EPICS Archiver Appliance accept waveforms? The documentation suggests it does, but I was unable to add one (after initial sampling its status is 'not being archived').
You may be running afoul of a policy condition.
cf. the default policy.
https://github.com/slacmshankar/epicsarchiverap/blob/master/src/sitespecific/slacdev/classpathfiles/policies.py <https://github.com/slacmshankar/epicsarchiverap/blob/master/src/sitespecific/slacdev/classpathfiles/policies.py>
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu <http://www.chess.cornell.edu> <http://www.chess.cornell.edu <http://www.chess.cornell.edu>>
Re: Waveforms in Archiver Appliance John Dobbins via Tech-talk
Re: Waveforms in Archiver Appliance Michael Davidsaver via Tech-talk
Prev: Re: Waveforms in Archiver Appliance John Dobbins via Tech-talk
Next: Re: Waveforms in Archiver Appliance John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
