1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Waveforms in Archiver Appliance
From: "Shankar, Murali via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 22 Apr 2022 14:25:21 +0000
I tried fetching a waveform with "R2020a (9.8.0.1323502) 64-bit (glnxa64)" and it works for me so I think getting waveforms into Matlab should be supported.
>> dat = load('temp.mat')
>> try
    header = dat.header;
    data = "">
catch
    fprintf('Could not get data from file\n');
    return
end
>> header
header =
  struct with fields:
    source: 'Archiver appliance'
    pvName: '....:VOLT_BUFFER_RBV'
        to: '2022-04-21T13:15:10.000Z'
>> data
data ="">
  struct with fields:
    epochSeconds: [2x1 int64]
          values: [2x1000 double]
           nanos: [2x1 int64]
           isDST: [2x1 uint8]
Have you tried using curl to check the size of the file you get back to make sure there is data in the time frame you are looking for?
curl -s "https://.../retrieval/data/getData.mat?pv=...:VOLT_BUFFER_RBV&from=2022-04-21T13:15:00.000Z&to=2022-04-21T13:15:10.000Z" | wc
3      41    1194
Murali
Re: Waveforms in Archiver Appliance John Dobbins via Tech-talk
Prev: Controls Software Engineer / Python Developer (f/m/d) Steffen Hauf via Tech-talk
Next: Re: Waveforms in Archiver Appliance John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: Waveforms in Archiver Appliance Michael Davidsaver via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
