1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: Heinz Junkes <junkes at fhi-berlin.mpg.de>
Cc: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 22 Apr 2022 12:41:17 -0700
On 4/22/22 11:51, Heinz Junkes via Tech-talk wrote:
we need to route the announcements from our central Channelfinder server to a subnet so that the
recasters on the IOCs in the subnet can send their PV information to the server.
Unfortunately, the announcement package does not contain the IP of the server but FF:FF:FF:FF.
How are you planning to "route"?
Playing games with routing rules, or mangling via. something like iptables/netfilter won't change
the IP source address, which is what SERV ADDR == 0xffffffff means (as with CA or PVA).
If you are thinking to create an active repeater (application level proxy), then this app. will
need to copy the original IP source address into SERV ADDR field.
https://github.com/ChannelFinder/recsync#udp-protocol
root@priscilla:~# socat -ls -u -v -x UDP4-RECVFROM:5049,broadcast,fork,bind=141.14.143.255 UDP4-SENDTO:10.0.1.255:5049,broadcast
2022/04/22 17:22:18.879313  length=16 from=0 to=15
52 43 00 00 ff ff ff ff 84 81 00 00 61 bf c1 23  RC..........a..#
Gruss Heinz
Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address Heinz Junkes via Tech-talk
Prev: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address Heinz Junkes via Tech-talk
Next: Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
