TL;DR: it now works with Heinz' suggestion: longer explanation: we have multiple small labs with own, dedicated networks, that
NAT outgoing traffic. so routing is not an option. next idea was to translate the recceivers broadcast signal into
the private lab network, via iptables, kind of a reverse NAT if
you will. but as it turned out, iptables doesnt handle broadcast packets so I switched to socat which does. since the reccasters in the IOCs only respond to the address in the 16byte message, the response never got through... but now, with the correct and dedicated IP of the channelfinder server in it, it works perfectly. :) by the way: FF FF FF FF as an IP address doesnt make sense to me
anyways. - William
Am 25.04.2022 um 13:01 schrieb Heinz
Junkes via Tech-talk:
Hallo Han, thanks for the hint. But this only works if the computer system also has a “leg” (network connection) into the respective networks? We also have something like this for the FEL network, for example. But otherwise there are always gateway computers between the individual experiment networks und the main-net. However, since we are routing out of the experiment machines into our main-net, I'll try my hand at modifying announce.py. tcpaddr='\xff\xff\xff\xff’ -> tcpaddr='\x8d\x0e\x8c\x62’ (141.14.140.98) HeinzOn 24. Apr 2022, at 02:43, Han Lee <jeonglee at lbl.gov> wrote: Hi Heinz, Could you try to add your IOC address subnets into the recceiver server configuration as addr_list? https://github.com/jeonghanlee/RecSync-env/blob/7b9fbc794ec8e4ae36349593780f9dcd00d142a0/site-template/recsync.conf.in#L16 Multiple IOCs just see the resync server (Not CF - elasticsearch - server) without issues. For example, you can add each subnet where your IOCs are running, such as 10.10.11.255:5049, 10.10.48.255:5049, .................................. I hope this is what you are looking for. Or I completely misunderstand your description. Best, Han On Fri, Apr 22, 2022 at 11:52 AM Heinz Junkes via Tech-talk <tech-talk at aps.anl.gov> wrote: Hi, we need to route the announcements from our central Channelfinder server to a subnet so that the recasters on the IOCs in the subnet can send their PV information to the server. Unfortunately, the announcement package does not contain the IP of the server but FF:FF:FF:FF. root@priscilla:~# socat -ls -u -v -x UDP4-RECVFROM:5049,broadcast,fork,bind=141.14.143.255 UDP4-SENDTO:10.0.1.255:5049,broadcast2022/04/22 17:22:18.879313 length=16 from=0 to=1552 43 00 00 ff ff ff ff 84 81 00 00 61 bf c1 23 RC..........a..# Gruss Heinz -- Jeong Han Lee, Dr.rer.nat Staff Scientist and Engineer Lawrence Berkeley National Laboratory 1 Cyclotron Road Mailstop 46R0161 Berkeley, CA 94720, United States Tel :+1-510-486-6163 Cell:+1-510-384-3868 Attachment:
smime.p7s
ANJ, 14 Sep 2022 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
