1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Eiger Stream API problems
From: "Zimoch Dirk \(PSI\) via Tech-talk" <tech-talk at aps.anl.gov>
To: "amiceli at anl.gov" <amiceli at anl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 25 Apr 2022 15:55:43 +0000
I find it interesting that it reports a parse error in the header at time stamps with minutes 08 and 09, two numbers
starting with 0 but not octal. Is anything parsing the time stamp with %i instead of %d?
Dirk
On Mon, 2022-04-25 at 15:49 +0000, Miceli, Antonino via Tech-talk wrote:
> Hi
> Has anyone see these errors with ADEiger like this?
> eigerDetector:streamTask: failed to get header packet
> eigerDetector:streamTask: got Strat packet, ignoring
> See IOC and MEDM screenshots here:
> https://anl.box.com/s/rntjlgvg903g02w2k1e7kvidsypq0g8m
> https://anl.box.com/s/2gwpcl1s9gnbd7dt2ewdakkztfrhu2jc
> It did not happen immediately after a fresh reboot of IOC, while it occurred after we took data for a while when the
> IOC gave some error message about the Stream Api. You can also see in the last photo that the Steam state shows
> "disabled" even though it was set to enable. This happened no matter I set the header detail to "None" or "Basic". As
> this issue happened, the number on image counter didn't update while the default FileWriter still wrote frames into
> hdf5 files.
> (Ignore the autosave error).
> Thanks,
> Nino
Eiger Stream API problems Miceli, Antonino via Tech-talk
Prev: Eiger Stream API problems Miceli, Antonino via Tech-talk
Next: RE: Eiger Stream API problems Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
