On 4/26/22 02:43, Kuldeep Joshi wrote:
> for pyDevSup, any suggestions as to how I can automate switching to the virtual environment before invoking the IOC?? (source ~/myvirtEnv/bin/activate??? at the start of st.cmd file??)
All the 'activate' script does these days is modify $PATH so yoy
can instead directly reference 'bin/python` in a virtualenv.
> /path/to/env/bin/python myscript.py
How do I point the path to the virtual environment so that the IOC can use it.
If practical, (re)build pyDevSup against that specific interpreter.
make PYTHON=/path/to/env/bin/python
Alternately, if you are certain that the ABI versions match, you can
add $(TOP)/python$(PY_VER) to $PYTHONPATH and "import devsup". The
"softIocPy*" executable isn't as special as it used to be. For an
example run:
make ipython
which is a shortcut to run an ipython shell with $PYTHONPATH set
appropriately to for the $PYTHON used.
Also, I will mention
https://dls-controls.github.io/pythonSoftIOC/master/index.html
as possible an alternative which fits better into the python
ecosystem (cf. "pip install softioc").
W.R.T.
#!../../bin/linux-x86_64/softIocPy2.7
# Interpreter not started
dbLoadDatabase("../../dbd/softIocPy.dbd",0,0)
softIocPy_registerRecordDeviceDriver(pdbbase)
# Interpreter started
or
> #!/path/to/env/bin/python
How do I do it while invoking the IOC, with st.cmd file where it is the #!/path/points/to/the/softioc
I am presently having another bash script file from which I activate the the virtual environment and invoking the st.cmd file
- pyDevSup and PyDevice: Virtual Environment Kuldeep Joshi via Tech-talk
- Re: pyDevSup and PyDevice: Virtual Environment Michael Davidsaver via Tech-talk
- Re: pyDevSup and PyDevice: Virtual Environment Kuldeep Joshi via Tech-talk
RE: Olog Features Leblanc, Gregory via Tech-talk
RE: Re: Getting Permission denied messages while building Barrett (US), Patrick E via Tech-talk
<2022>
2025
Eiger Stream API problems Miceli, Antonino via Tech-talk
<2022>
2025
