I can start succesfully ImageJ and select under plugins EPICS_areaDetector the EPICS AD VIEWER. I see the message 'PVs is connected' in the the status window. When I press the Start button to begin displaying images, nothing happens. You can see this behavior with the attached files. I tried it with 13SIM1:image1 and 13ARV1:image1 to get pictures from my camera. You can notice that there are no values for NX, NY, NZ and Frames/s. When you look at the NDStdArrays.adl, you notice the configuration of the array is not done, dimension and array size is 0. What do I forget in the configuration or misconfigured? Best regards Petra --
Petra Schwalbach
Petra.Schwalbach at uni-mainz.de
Privat: mobil 0151 58854122 Festnetz 06131 593275 Inst. f. Kernphysik, Uni Mainz Tel.: 06131/39-25193 B1-Kollaboration Fax: 06131/39-22964 Johann-Joachim-Becher-Weg 45 http://portal.kph.uni-mainz.de/B1/ 55099 Mainz Attachment:
ImageJ_13ARV1_adl.jpg Attachment:
ImageJ_13SIM1_adl.jpg Attachment:
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
