Hm… I am not explicitly calling release() anywhere. This is my processCallbacks function- everything else in my plugin, AFAIK, doesn’t access any shared resources.
void NDPluginTemperature::processCallbacks(NDArray *pArray){
static const char *functionName = "processCallbacks";
NDArrayInfo_t arrayInfo;
if(pArray->dataType != NDUInt16){
asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
"%s:%s: Only UInt16 supported.", driverName, functionName);
return;
std::string lastCalFileName = this->calibrationFileName;
getStringParam(this->calibrationFileNameIdx, this->calibrationFileName);
if(this->calibrationFileName != lastCalFileName){
this->processCalibrationFile();
int arrayCallbacks;
getIntegerParam(NDArrayCallbacks, &arrayCallbacks);
if(arrayCallbacks==1){
epicsTimeStamp before;
epicsTimeGetCurrent(&before);
NDPluginDriver::beginProcessCallbacks(pArray);
this->pNDArrayPool->convert(pArray,&(this->inputArray), NDUInt16);
if(NULL == this->outputArray){
this->pNDArrayPool->convert(pArray,&(this->outputArray),NDUInt16);
//unlock while the plug-and-chug happens. No shared resources are accessed at this time.
inputArray->getInfo(&arrayInfo);
this->unlock();
this->doTemperatureConversion(this->inputArray, this->outputArray, &arrayInfo);
this->lock();
setIntegerParam(NDArraySizeX, (int)outputArray->dims[arrayInfo.xDim].size);
setIntegerParam(NDArraySizeY, (int)outputArray->dims[arrayInfo.yDim].size);
epicsTimeStamp after;
epicsTimeGetCurrent(&after);
double delta = epicsTimeDiffInSeconds(&after, &before);
cout<<"Took "<<delta<<" s"<<endl;
setDoubleParam(runTimeIdx, delta);
NDPluginDriver::endProcessCallbacks(outputArray, false, true);
callParamCallbacks();
Sent: Tuesday, May 3, 2022 11:37 AM
To: tech-talk at aps.anl.gov; Daykin, Evan <daykin at frib.msu.edu>
Subject: Re: NDArrayPool:reserve ERROR, reference count = 0, should be = 1
[EXTERNAL] This email originated from outside of FRIB
Hi Evan,
That error probably means you have called NDArray::release() on an array whose reference count is already 0.
Most plugins don't need to call release() because it is handled in the base class NDPluginDriver::endProcessCallbacks().
I am hoping there’s an AreaDetector plugin maven here…
I have written a small AD plugin intended to convert our raw camera images into a temperature heatmap, based on a calibrated gain, emissivity and exposure time. To test it, I set up a SimDetector in “peak” mode. I connect my plugin to this simDetector image.
I can successfully capture and convert 3 frames. On the fourth frame, my test dies with the following error. Are there any common pitfalls that might cause this?
NDArray.uniqueId=1
Do temperature conversion start
Took 0.0937809 s
NDArray.uniqueId=2
Took 0.0655851 s
NDArray.uniqueId=3
Took 0.0642867 s
NDArray.uniqueId=4
NDArrayPool:reserve ERROR, reference count = 0, should be >= 1, pArray=0x7f453c001d80
Thread SimDetTask (0x5621bbbb0c80) can't proceed, suspending.
Dumping a stack trace of thread 'SimDetTask':
[ 0x7f45538ffab3]: /lib/x86_64-linux-gnu/libCom.so.3.15.9(epicsStackTrace+0x73)
[ 0x7f45538f0216]: /lib/x86_64-linux-gnu/libCom.so.3.15.9(cantProceed+0xc6)
[ 0x7f4553197b08]: /lib/x86_64-linux-gnu/libADBase.so.3.11(_ZN11NDArrayPool7reserveEP7NDArray+0x78)
[ 0x7f455305db37]: /lib/x86_64-linux-gnu/libNDPlugin.so.3.11(_ZN14NDPluginDriver21beginProcessCallbacksEP7NDArray+0x367)
[ 0x7f455375df1e]: /home/daykin/git/areadetector-temperature/lib/linux-x86_64/libNDPluginTemperature.so(_ZN19NDPluginTemperature16processCallbacksEP7NDArray+0xae)
[ 0x7f455305dd53]: /lib/x86_64-linux-gnu/libNDPlugin.so.3.11(_ZN14NDPluginDriver14driverCallbackEP8asynUserPv+0x1d3)
[ 0x7f4553851155]: /lib/x86_64-linux-gnu/libasyn.so.4.38(_ZN14asynPortDriver25doCallbacksGenericPointerEPvii+0x1f5)
[ 0x7f4553809974]: /usr/lib/epics/lib/linux-x86_64/libsimDetector.so(_ZN11simDetector7simTaskEv+0x4e4)
[ 0x7f45538fa0bb]: /lib/x86_64-linux-gnu/libCom.so.3.15.9(epicsSnprintf+0x7bb)
[ 0x7f4553387ea7]: /lib/x86_64-linux-gnu/libpthread.so.0(start_thread+0xd7)
[ 0x7f455349edef]: /lib/x86_64-linux-gnu/libc.so.6(clone+0x3f)
Evan Daykin
Controls Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7678
Email: daykin at frib.msu.edu
