1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Polynomial Transformation / Curve Fitting in EPICS
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, Kuldeep Joshi <kuldeep.joshi at gmail.com>
Date: Fri, 6 May 2022 12:59:10 +0000
Hi Kuldeep,
> Can anyone please suggest to me any module in EPICS/SynApps which allows for user selectable linear, quadratic and polynomial based transformation.
What do you mean by "transformation"?  A linear "transformation" could mean Out = A + B*In which the aCalcout record can certainly do.
Your next sentence suggests you mean curve fitting.  In that case please explain what "transform both ways" means.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Kuldeep Joshi via Tech-talk <tech-talk at aps.anl.gov>
Sent: Friday, May 6, 2022 12:16 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Polynomial Transformation / Curve Fitting in EPICS
Hello,
Can anyone please suggest to me any module in EPICS/SynApps which allows for user selectable linear, quadratic and polynomial based transformation. I should be able to transform both ways and recalibrate the curve fitting coefficients in the field.
Thank you in advance.
Kuldeep
Polynomial Transformation / Curve Fitting in EPICS Kuldeep Joshi via Tech-talk
Prev: Re: Embedding pyPVA server in EPICS IOC: How? Mark Rivers via Tech-talk
Next: Re: Generating EPICS records from a spreadsheet Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Polynomial Transformation / Curve Fitting in EPICS Kuldeep Joshi via Tech-talk
Next: Generating EPICS records from a spreadsheet Ian Gillingham via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
