Thanks for the suggestion. I am using Phoebus for display and control. Its table widget can display a pvaccess table. I guess it also can display individual PV array in each column. How does one display NTNDArrays in tabular format on phoebus. How do i insert a custom algorithm, which may change the array dimensions and display it in tabular format. I am thinking of making this algorithm using sympy as i feel ACalcout will have limitation on the number of arrays. Basically i wanted to avoid using building for these changes, like LUA, Python. Unlike asub or snc where prior build is required. Say computing statistical distribution over multiple scans. Whatever examples i saw for phoebus are more on image processing and image display. Can you point me to one with tabular display. It would be great if i can embedded python pvaccess server in the ioc. This will allow me to integrate multiple CA PVs and make a composite device using pypva. Regards, Kuldeep On Friday, May 6, 2022, Mark Rivers <rivers at cars.uchicago.edu> wrote: > Hi Kuldeep, > There is an areaDetector driver called NDDriverStdArrays that is intended to do more or less what you want, but without Python. It listens for CA monitors on arrays (like those from the sscan record) and puts them into NTNDArrays that can be published with PVA via NDPluginPva. It has a number of operating options, and so might be able to do what you want. > https://areadetector.github.io/master/NDDriverStdArrays/NDDriverStdArraysDoc.html > > I realize this does not answer your original question, which is about using Python. > Mark > ________________________________ > From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Kuldeep Joshi via Tech-talk <tech-talk at aps.anl.gov> > Sent: Friday, May 6, 2022 12:09 AM > To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov> > Subject: Embedding pyPVA server in EPICS IOC: How? > > Hello, > I am presently having an EPICS IOC with CA protocol, with SynApps toolkit. ( can python softIoc be used with SynApps) > I wanted the data to be displayed in a Tabular format. For this I set up a separate multi threaded python process, with pyepics on the client side, gathering (monitoring for change) the data from the SynApps SScan Module, this data is processes and published on a python pvaccess server (pypva) in a tabular format. > Here I intentionally kept the processing in python code as the user has flexibility to adapt the code without recompiling. > The EPICS IOC and the python (pyepics client, pypva server) are started as separate processes. I can use procserv to initiate the IOC as well as the python based CA and PVA client-server. > > I was wondering if by using pyDevSup or PyDevice, can I directly monitor the SScan data from the IOC and publish it directly to the python pvaccess server. This will save me one external CA connection. ie is it possible in pyDevSup and PyDevice to use the internal mechanism of IOC for monitoring and acquiring data. > > The attempted connection is as below. Is there an easier/elegant way? > > <-------------------------------------------------------> > EPICS IOC <--> pyepics <---> pypva <---> phoebus > > I tried embedding the above python client server code using pyDevSup and PyDevice I am getting similar warnings in both modules. > cas warning: Configured TCP port was unavailable. > cas warning: Using dynamically assigned TCP port 34549, > cas warning: but now two or more servers share the same UDP port. > cas warning: Depending on your IP kernel this server may not be > cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST) > iocRun: All initialization complete > > I guess it has to do with the same port used by the IOC and pyepics. How do I separate the port on the client and server side so as to avoid conflict. > > Regards, > Kuldeep Joshi > PS: I am using the following sequence (in pyepics) as given in the SScan documentation to gather the data > > Create local variables to hold cached values of the fields to be monitored, and a local variable (which I'll call "numPoints") to hold the number of data points accumulated. > Monitor DnnCV, RmCV and VAL (scalar data and control fields). > Monitor DnnDA, PmRA, DATA, and CPT (array data and control fields). > Whenever DnnCV, RmCV, or CPT are received, cache the received scalar value in a local variable. > Whenever DnnDA or PmRA are received, cache the received array value in a local variable. > When DATA="" is received, clear all data arrays, and reset numPoints to zero. > When VAL is received, append to all data arrays from cached scalar values, and increment numPoints. > When DATA="" is received, clear all data arrays and replace with cached array values; set numPoints to the cached value received from CPT.
ANJ, 14 Sep 2022 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
