1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Can't create mutex semaphore: too many
From: Joel Sherrill via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: "Luchini, Kristi L." <[email protected]>, Talk EPICS Tech <[email protected]>
Date: Mon, 9 May 2022 18:42:55 -0500
On Mon, May 9, 2022, 5:45 PM Michael Davidsaver via Tech-talk <[email protected]> wrote:
On 5/9/22 15:08, Luchini, Kristi L. via Tech-talk wrote:
> Hello,
> I have a MVME6100 ioc running RTEMS that appears to be having a resource issue.  Does anyone recognize these error messages below and happen to know function call that I can add to the st.cmd to increase that resource? Do  I need to increase the number file descriptors?
> If I reboot the ioc the message will go away and the iocs works fine, but after some period of time, a month or so, this message reappears and you can’t access pvs over CA, which I assume is because the iocs seems to be too busy spewing error messages.
> Any help would be appreciated.
Sounds like there is a resource leak somewhere, at least of RTEMS semaphores.
I'm not sure if the mention of "file descriptor" is real, or a case of
overloading the meaning of an errno code.
Which drivers and other code is being loaded?
Are any of these creating worker threads after iocInit() ?
Are there any earlier error messages being logged?
You could try running "epicsThreadShowAll()" to see if some driver threads are
hanging around when they shouldn't.
Unfortunately, there is no "epicsMutexShowAll" implemented for RTEMS 4.X, and
I don't know if your RTEMS builds include the RTEMS shell and its associated
diagnostics functions.
I don't know what RTEMS configure options are used but there is an option for unlimited and another for unified workspace. If they both are configured, you have one pool of memory to allocate everything from. This includes RTEMS objects and things you allocate via malloc() and new. In this configuration, any leak would be bad and could lead to this. It would just be a matter of which create or allocate failed. Malloc() will return NULL in this situation and that often isn't error checked.
--joel
> Thanks,
> Kristi
> Message from RTEMS ioc:
> Cexp@ioc-in10-mp01>
> Cexp@ioc-in10-mp01>Error on UDP RX 172.27.72.43:47591 -> 172.27.75.255:5076 at 46 : Can't create mutex semaphore: too many
> epicsMutex::mutexCreateFailed()
> 0x00 ca024000 27000000 d5b37962 00000000  ..@. '... ..yb ....
> 0x10 c84f9922 00740000 00000000 00000000  .O." .t.. .... ....
> 0x20 0000ffff 00000000 d3130374 6370ff    .... .... ...t cp.
> CAS: Client accept error: Too many open files in system (16)
> Error on UDP RX 172.27.72.99:37311 -> 172.27.75.255:5076 at 46 : Can't create mutex semaphore: too many
> 0x00 ca024000 27000000 a5a77862 00000000  ..@. '... ..xb ....
> 0x10 ea850c38 004f0000 00000000 00000000  ...8 .O.. .... ....
>   * Kristi
Re: Can't create mutex semaphore: too many Michael Davidsaver via Tech-talk
RE: Can't create mutex semaphore: too many Luchini, Kristi L. via Tech-talk
Prev: RE: Can't create mutex semaphore: too many Luchini, Kristi L. via Tech-talk
Next: Re: Can't create mutex semaphore: too many Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
