1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Only cross compile option
From: Han Lee via Tech-talk <tech-talk at aps.anl.gov>
To: Florian Feldbauer <florian at ep1.ruhr-uni-bochum.de>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 10 May 2022 20:43:11 -0700
Hi Mark and Florian,
You are great! It works perfectly.
Han
On Tue, May 10, 2022 at 12:49 PM Florian Feldbauer via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hey Mark,
you are right...I just searched tech-talk for the solution I got.
https://epics.anl.gov/tech-talk/2020/msg00369.php
Andrew suggested the following change, which worked for me
Where the Makefile says something like
  PROD_IOC = <iocname>
replace it with this:
  PROD_IOC_linux-arm = <iocname>
  PROD_IOC += $(PROD_IOC_$(T_A))
The second line is needed, because as you said the syntax is only working for OS_CLASS not T_A.
Cheers,
Florian
Am 10.05.2022 um 21:46 schrieb Mark Rivers:
Ø  PROD_IOC_linux-arm = <name>
I think this syntax only work for OS_CLASS, not for target architecture (TA)
So it works for
PROD_IOC_Linux = <name>
But for linux-arm I think you need to do:
ifeq (linux-arm, $(findstring linux-arm, $(T_A)))
endif
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Florian Feldbauer via Tech-talk
Sent: Tuesday, May 10, 2022 2:39 PM
To: tech-talk at aps.anl.gov
Hey Han,
yes, there is a way. I did this once too.
If I remember correctly you simply need to change the line
PROD_IOC = <name>
to
in your <ioc>APP/src/Makefile
HTH Florian
Am 10.05.2022 um 21:31 schrieb Han Lee via Tech-talk:
Hi EPICSers,
I have an IOC, I want to compile it with only target architecture, for example, linux-arm. My host is linux-x86_64. EPICS base and modules can be compiled through the standard method with Host and target well with os/CONFIG_SITE.linux-x86_64.linux-arm.
But due to the specific libs, and header files for this IOC, I want to exclude the host compilation.
Is there any way to force to compile this IOC only for target Archture?
Best,
Han
Jeong Han Lee, Dr.rer.nat
Staff Scientist and Engineer
Lawrence Berkeley National Laboratory
1 Cyclotron Road Mailstop 46R0161
Berkeley, CA 94720, United States
Tel :+1-510-486-6163
Cell:+1-510-384-3868
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
NB 2/131 / Fach 125
D-44801 Bochum
Office: NB 2/134
Only cross compile option Han Lee via Tech-talk
Re: Only cross compile option Florian Feldbauer via Tech-talk
RE: Only cross compile option Mark Rivers via Tech-talk
Prev: 2 Open Positions at Gemini/NOIRLab Matt Rippa via Tech-talk
Next: PI controller C-887 Jong Woo Kim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: Only cross compile option Florian Feldbauer via Tech-talk
Next: 2 Open Positions at Gemini/NOIRLab Matt Rippa via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
