1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Subject: AW: Regex support in StreamDevice.
From: "Zimoch Dirk \(PSI\) via Tech-talk" <tech-talk at aps.anl.gov>
To: "Li, Ji" <liji at bnl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 13 May 2022 14:04:49 +0000
Do you see %/ in dbior?
epics> dbior stream,1
Driver: stream
  StreamDevice 2.8.22 2021-11-11 11:49:32 +0100
  commit: 94721c2b0e2ae118778d5783bd35cc642f573f60
  (C) 1999 Dirk Zimoch (dirk.zimoch at psi.ch)
  Use interest level 100 for license information
  registered bus interfaces:
    AsynDriverInterface
    DebugInterface
    DummyInterface
  registered converters:
    %/ RegexpConverter
    %< ChecksumConverter
    %B BinaryConverter
    %D BCDConverter
    %E StdDoubleConverter
    %G StdDoubleConverter
    %R RawFloatConverter
    %T TimestampConverter
    %X StdLongConverter
    %[ StdCharsetConverter
    %b BinaryConverter
    %c StdCharsConverter
    %d StdLongConverter
    %e StdDoubleConverter
    %f StdDoubleConverter
    %g StdDoubleConverter
    %i StdLongConverter
    %m MantissaExponentConverter
    %o StdLongConverter
    %r RawConverter
    %s StdStringConverter
    %u StdLongConverter
    %x StdLongConverter
    %{ EnumConverter
  connected records:
Von: Li, Ji <liji at bnl.gov>
Gesendet: Freitag, 13. Mai 2022 15:55
An: Zimoch Dirk (PSI) <dirk.zimoch at psi.ch>; tech-talk at aps.anl.gov
Betreff: Re: Regex support in StreamDevice.
Hi Dirk,
Thanks for the suggestion. The StreamDevice was installed from a prebuilt package and it seems to have PCRE linked:
liji@xf04bm-maia:/epics/iocs/maia$ ldd bin/linux-x86_64/maia |grep stream
libstream.so => /usr/lib/epics/lib/linux-x86_64/libstream.so (0x00007f0139e55000)
liji@xf04bm-maia:/epics/iocs/maia$ ldd /usr/lib/epics/lib/linux-x86_64/libstream.so |grep pcre
libpcre2-8.so.0 => /lib64/libpcre2-8.so.0 (0x00007fecb0427000)
Something must have broken. I compiled a seperate StreamDevice instance and rebuilt the IOC. Errors are gone. We will double check the StreamDevice package. Thanks.
Best,
-Ji
Sent: Friday, May 13, 2022 2:28
To: Li, Ji <liji at bnl.gov>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Hi Ji
It looks like PCRE (perl regular expressions) is not linked into StreamDevice.
Check your PCRE settings in RELEASE.
Be aware that from StreamDevice 2.7 to 2.8 I made some modifications to the Makefiles when searching for the configure directory to be more "standard EPICS compatible". In particular I look into the local configure first instead of an upper level configure. So maybe you need to copy some settings over?
Dirk
Von: Tech-talk <tech-talk-bounces at aps.anl.gov> Im Auftrag von Li, Ji via Tech-talk
Gesendet: Donnerstag, 12. Mai 2022 23:47
An: tech-talk at aps.anl.gov
Betreff: Regex support in StreamDevice.
We have an IOC based on streamdevice which had been work well until it was recently updated to base 7.0.5 and StreamDevice 2.8.10. The IOC reported erros on startup:
2022/05/12 17:20:06.024569 _main_ No converter registered for format '%/'
2022/05/12 17:20:06.024610 _main_ var.p line 398: in format string: "%/^(?|\"([^\"]*)\"|([^\"][^ ]*))/"
2022/05/12 17:20:06.024616 _main_ var.p line 398: in command 'in'
2022/05/12 17:20:06.024620 _main_ var.p line 395: in protocol 'var_g_string'
2022/05/12 17:20:06.024627 _main_ while compiling protocol 'var_g_string(position.dim[0].name,XFM:MAIA)' for 'XFM:MAIA:X_POS_DIM_NAME'
2022/05/12 17:20:06.024633 _main_ XFM:MAIA:X_POS_DIM_NAME: Protocol parse error
2022/05/12 17:20:06.024639 _main_ XFM:MAIA:X_POS_DIM_NAME: Record initialization failed
It seems "%/^(?|\"([^\"]*)\"|([^\"][^ ]*))/" in protocol var_g_string could not be recognized as a regular _expression_.
The StreamDevice was built against PCRE package, and:
liji@xf04bm-maia:/epics/iocs/maia$ ldd bin/linux-x86_64/maia | grep pcre
libpcre2-8.so.0 => /lib64/libpcre2-8.so.0 (0x00007fcd23fdb000)
What could be preventing streamdevice from parsing protocols with regular expressions?
Best,
-Ji
Re: Regex support in StreamDevice. Li, Ji via Tech-talk
AW: Regex support in StreamDevice. Zimoch Dirk (PSI) via Tech-talk
Prev: Re: Regex support in StreamDevice. Li, Ji via Tech-talk
Next: Re: Regex support in StreamDevice. Li, Ji via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
