Well,
If logging out (detaching) from a running IOC is the missing functionality, let me point you back to the procServ man page: ----- snip ----- Any connection (control or log) can be disconnected using the client's disconnect sequence. Control connections can also be disconnected by sending the logout command character that can be specified using the *-x* (*\--logoutcmd*) option. ----- snip ----- This option will let you define a control character to have the procServ server disconnect the client session from the procServ side. Intended for clients that don't offer a disconnect sequence. Cheers, ~Ralph
ANJ, 14 Sep 2022 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
