1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: autosave problem
From: Abdalla Ahmad via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, "Johnson, Andrew N." <anj at anl.gov>, "mooney at aps.anl.gov" <mooney at aps.anl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 31 May 2022 11:09:19 +0000
I faced the exact issue when working with AD Core request file. I found out that string PVs with empty values will cause 0 bytes to be printed, for example ShutterOpenEPICS.OUT and ShutterCloseEPICS.OUT. If the PV was empty the save file will not be written successfully, but when you set these PVs autosave will correctly write the autosave file.
It does not make sense for autosave to fail writing the file if a PV was empty, I reverted to 5.10.2 and the file was written successfully.
Best Regards,
Abdalla.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Mark Rivers via Tech-talk
Sent: Thursday, May 19, 2022 2:12 AM
To: Johnson, Andrew N. <anj at anl.gov>; mooney at aps.anl.gov
Cc: tech-talk at aps.anl.gov
I am quite sure this change between the latest tagged version (R5-10-2) and the master branch is the problem:
                } else if (pchannel->curr_elements <= 1) {
                        /* treat as scalar */
                        if (pchannel->enum_val >= 0) {
                                n = fprintf(out_fd, "%d\n",pchannel->enum_val);
                        } else {
-                               n = fprintf(out_fd, "%-s\n", pchannel->value);
+                               n = epicsStrPrintEscaped(out_fd, pchannel->value, strlen(pchannel->value));
+                               if (n > 0) {
+                                       n = fprintf(out_fd, "\n");
                } else {
                        /* treat as array */
                        n = SR_write_array_data(out_fd, pchannel->name, (void *)pchannel->pArray, pchannel->curr_elements);
                if (n <= 0) {
                        printf("save_restore:write_it: fprintf returned %d [%s].\n", n, datetime);
                        if (errno) myPrintErrno("write_it", __FILE__, __LINE__);
                        problem |= FPRINTF_FAILED;
Note that previously it used fprintf including a newline, so it would always return >0 as long as there was no error.
Now n is set by epicsStrPrintEscaped which might return 0, and only if it is >0 does it print a newline which will set n to 1.  This seems wrong for 2 reasons:
-          If epicsStrPrintEscaped returns 0 then there will be no newline, and the next PV in the output file will be on the same line as this one.
-          If epicsStrPrintEscaped returns 0 then it fails the n<=0 test, prints and error and never writes the file.
The commit with this error was done on November 14, 2019.
https://github.com/epics-modules/autosave/commit/7fee24c91a37bc3a69420d6bb17732c839ba0cf8
However, it is not present in the R5-10-1 tag (April 17, 2020) or the R5-10-2 tag (October 4, 2020), because that PR was not merged until March 19, 2022.
I just reverted to R5-10-2 and the autosave issue is fixed, my files are fine and the error messages no longer occur.
Sent: Wednesday, May 18, 2022 5:40 PM
This really seems like a problem in autosave.
The save_restore:write_it function prints the same error message in 5 different places when fprintf() returns <=0.  I improved the code so it prints additional information so I know which error it is, and when it is writing data which PV it is writing. That additional information is highlighted in yellow below.
This is the output from 3 different VME IOCs running the new version of save_restore.c
corvette:CARS/iocBoot/ioc13ida>tail -10 ~/logs/13IDA.log
[Wed May 18 17:26:04 2022] save_restore:write_it: fprintf returned 0 when writing data for channel 13IDA:DMM1Dmm_calc.INPB [220518-172604].
[Wed May 18 17:26:04 2022] save_restore:write_it: Giving up on this attempt to write 'auto_settings.sav'. [220518-172604]
[Wed May 18 17:26:04 2022] *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
[Wed May 18 17:26:04 2022] save_restore:write_save_file: Can't write save file. [220518-172604]
[Wed May 18 17:26:34 2022] save_restore:write_it: fprintf returned 0 when writing data for channel 13IDA:DMM1Dmm_calc.INPB [220518-172634].
[Wed May 18 17:26:34 2022] save_restore:write_it: Giving up on this attempt to write 'auto_settings.sav'. [220518-172634]
[Wed May 18 17:26:34 2022] *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
[Wed May 18 17:26:34 2022] save_restore:write_save_file: Can't write save file. [220518-172634]
corvette:CARS/iocBoot/ioc13ida>tail -10 ~/logs/13BMA.log
[Wed May 18 17:25:53 2022] save_restore:write_it: fprintf returned 0 when writing data for channel 13BMA:DMM1Dmm_calc.INPB [220518-172553].
[Wed May 18 17:25:53 2022] save_restore:write_it: Giving up on this attempt to write 'auto_settings.sav'. [220518-172553]
[Wed May 18 17:25:53 2022] *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
[Wed May 18 17:25:53 2022] save_restore:write_save_file: Can't write save file. [220518-172553]
[Wed May 18 17:25:54 2022] *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
[Wed May 18 17:26:23 2022] save_restore:write_it: fprintf returned 0 when writing data for channel 13BMA:DMM1Dmm_calc.INPB [220518-172623].
[Wed May 18 17:26:23 2022] save_restore:write_it: Giving up on this attempt to write 'auto_settings.sav'. [220518-172623]
[Wed May 18 17:26:24 2022] *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
[Wed May 18 17:26:24 2022] save_restore:write_save_file: Can't write save file. [220518-172623]
corvette:CARS/iocBoot/ioc13ida>tail -10 ~/logs/13BMC.log
[Wed May 18 17:25:58 2022] save_restore:write_it: fprintf returned 0 when writing data for channel 13BMC:DMM1Dmm_calc.INPB [220518-172559].
[Wed May 18 17:25:59 2022] save_restore:write_it: Giving up on this attempt to write 'auto_settings.sav'. [220518-172559]
[Wed May 18 17:25:59 2022] *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
[Wed May 18 17:25:59 2022] save_restore:write_save_file: Can't write save file. [220518-172559]
[Wed May 18 17:26:29 2022] save_restore:write_it: fprintf returned 0 when writing data for channel 13BMC:DMM1Dmm_calc.INPB [220518-172629].
[Wed May 18 17:26:29 2022] save_restore:write_it: Giving up on this attempt to write 'auto_settings.sav'. [220518-172629]
[Wed May 18 17:26:29 2022] *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
[Wed May 18 17:26:29 2022] save_restore:write_save_file: Can't write save file. [220518-172629]
Note that they all fail when writing the INPB file of a calcout record.  This is dbpr on one of those records:
ioc13ida> dbpr "13IDA:DMM1Dmm_calc",1
A   : 9.9e+37       ADEL: 0             AMSG:               ASG :
B   : 0             BKPT: 00            C   : 0             CALC: A
CLCV: 0             D   : 0             DESC: Dmm Units     DISA: 0
DISP: 0             DISS: NO_ALARM      DISV: 1             DLYA: 0
DOPT: Use CALC      DTYP: Soft Channel  E   : 0             EGU :
EVNT:               F   : 0             FLNK: CONSTANT      G   : 0
H   : 0             HHSV: NO_ALARM      HIGH: 0             HIHI: 0
HOPR: 0             HSV : NO_ALARM      HYST: 0             I   : 0
INAV: Local PV      INBV: Constant      INCV: Constant      INDV: Constant
INEV: Constant      INFV: Constant      INGV: Constant      INHV: Constant
INIV: Constant      INJV: Constant      INKV: Constant      INLV: Constant
INPA: DB_LINK 13IDA:DMM1Dmm_raw.VAL NPP NMS                 INPB: CONSTANT
INPC: CONSTANT      INPD: CONSTANT      INPE: CONSTANT      INPF: CONSTANT
INPG: CONSTANT      INPH: CONSTANT      INPI: CONSTANT      INPJ: CONSTANT
INPK: CONSTANT      INPL: CONSTANT      J   : 0             K   : 0
L   : 0             LLSV: NO_ALARM      LOLO: 0             LOPR: 0
LOW : 0             LSV : NO_ALARM      MDEL: 0
NAME: 13IDA:DMM1Dmm_calc                NAMSG:              OCAL: 0
OCLV: 0             ODLY: 0             OEVT:               OOPT: Every Time
OUT : CONSTANT      OUTV: Constant      OVAL: 0             PACT: 0
PHAS: 0             PINI: NO            POVL: 0             PREC: 4
PRIO: LOW           PUTF: 0             PVAL: 0             RPRO: 0
SCAN: Passive       SDIS: CONSTANT      SEVR: INVALID       STAT: UDF
TPRO: 0             TSE : 0             TSEL: CONSTANT      UDF : 1
UDFS: INVALID       VAL : 0
value = 0 = 0x0
I suspect what is happening is that due to some recent commits the value being written is zero length, so fprintf is correctly returning 0, which is being misinterpreted as an error.
Sent: Wednesday, May 18, 2022 5:09 PM
Hi Andrew,
Ø  Were there any changes to your file-server? I'm hoping that's not the system that Mrinal was upgrading to CentOS-8 last week.
The file server has not changed, it is Centos 7.
Ø  1058 bytes is less than a single UDP packet; can you try writing some other largeish file from VxWorks, just to make sure that isn't related. There is a "copy" command which might work for that, you give it an existing filename and a new one.
I just copied a file of about 16 kB  using the vxWorks shell.
ioc13ida> copy "motors.template","junk.txt"
value = 0 = 0x0
It worked fine, the output file junk.txt is the same as the input file.
corvette:CARS/iocBoot/ioc13ida>ls -l motors.template junk.txt
-rwxrwxrwx 1 epics domain users 16959 Jan  1  2020 junk.txt
-rwxrwxr-x 1 epics domain users 16959 Jan  1  2020 motors.template
I am adding some debugging to save_restore:write_it to figure out which fprintf failed and perhaps why.
Sent: Wednesday, May 18, 2022 4:59 PM
To: Mark Rivers <rivers at cars.uchicago.edu>; mooney at aps.anl.gov
Subject: Re: autosave problem
Hi Mark,
Were there any changes to your file-server? I'm hoping that's not the system that Mrinal was upgrading to CentOS-8 last week. 1058 bytes is less than a single UDP packet; can you try writing some other largeish file from VxWorks, just to make sure that isn't related. There is a "copy" command which might work for that, you give it an existing filename and a new one.
- Andrew
On 5/18/22 4:52 PM, Mark Rivers wrote:
Folks,
I just upgraded my VME IOCs to base 7.0.6.1 and the master branch of autosave (some changes since 5-10-2).  I am getting these errors at the vxWorks prompt:
ioc13ida> save_restore:write_it: fprintf returned 0 [220518-163829].
save_restore:write_it: Giving up on this attempt to write 'auto_settings.sav'. [220518-163829]
save_restore:write_save_file: Can't write save file. [220518-163829]
Recent files in the autosave/ directory are:
-rw-rw-rw- 1 epics domain users   2749 May 18 16:37 auto_positions.sav_220518-163750
-rw-rw-rw- 1 epics domain users   1058 May 18 16:37 auto_settings.sav_RBAD_220518-163750
-rw-rw-rw- 1 epics domain users   1058 May 18 16:37 auto_settings.sav_220518-163751
-rw-rw-rw- 1 epics domain users   1058 May 18 16:37 auto_settings.sav_RBAD_220518-163751
-rw-rw-r-- 1 epics domain users   2749 May 18 16:37 auto_positions.sav
-rw-rw-rw- 1 epics domain users   2749 May 18 16:37 auto_positions.savB
-rw-rw-r-- 1 epics domain users   1058 May 18 16:41 auto_settings.sav
Note that it is writing files.  However, the auto_settings.sav file is only 1058 bytes long, while it should be about 160 kB.  It seems like save_restore:write_it is writing some information to the file and then it gets an error.
This is the contents of the auto_settings.sav file:
corvette:iocBoot/ioc13ida/autosave>more auto_settings.sav
# autosave R5.3 Automatically generated - DO NOT MODIFY - 220518-164400
13IDA:ip2:SAUTOS 0
13IDA:ip2:DIS 0
13IDA:ip2:SSIZE 400
13IDA:ip2:ULCK 1
13IDA:ip2:SIZE.SCAN 6
13IDA:ip2:STAT.SCAN 6
13IDA:ip8:SAUTOS 0
13IDA:ip8:DIS 0
13IDA:ip8:SSIZE 400
13IDA:ip8:ULCK 0
13IDA:ip8:SIZE.SCAN 4
13IDA:ip8:STAT.SCAN 6
13IDA:ip9:SAUTOS 0
13IDA:ip9:DIS 0
13IDA:ip9:SSIZE 400
13IDA:ip9:ULCK 0
13IDA:ip9:SIZE.SCAN 4
13IDA:ip9:STAT.SCAN 6
13IDA:tsp1:TSP_FIL 0
13IDA:tsp1:TSP_AUTO_ADV 0
13IDA:tsp1:TSP_VALUE 50
13IDA:tsp1:TSP_UNITS 0
13IDA:tsp1:TSP_SECONDS 50
13IDA:tsp1:TSP_MINUTES 240
13IDA:tsp1:TSP_NCYCLES 900
13IDA:tsp1:TSP_MIN_PRESS 1e-10
13IDA:tsp1:TSP_STAT.SCAN 9
13IDA:DMM1dmm_chan.VAL 1
13IDA:DMM1ch_mode_sel.VAL 6
13IDA:DMM1init_string.VAL *rst;form:elem read
13IDA:DMM1onesh_cont.VAL 1
13IDA:DMM1single_multi.VAL 1
13IDA:DMM1scanner.SCAN 6
13IDA:DMM1Dmm_raw.DESC Dmm raw desc
13IDA:DMM1Dmm_calc.DESC Dmm Units
13IDA:DMM1Dmm_calc.PREC 4
13IDA:DMM1Dmm_calc.SCAN 0
13IDA:DMM1Dmm_calc.CALC A
13IDA:DMM1Dmm_calc.INPA 13IDA:DMM1Dmm_raw.VAL NPP NMS
The disk that autosave it writing to has plenty of room.  What could be causing this error.
It is happening on all 8 of my VME IOCs, it is not just with one of them.
Complexity is free, it's Simplicity that takes work.
autosave problem Mark Rivers via Tech-talk
Re: autosave problem Johnson, Andrew N. via Tech-talk
RE: autosave problem Mark Rivers via Tech-talk
Prev: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Next: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: RE: autosave problem Mark Rivers via Tech-talk
Next: Re: autosave problem Laurenz Rettig via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
