1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: EPICS Tech Talk <[email protected]>, William Kirstaedter <[email protected]>
Date: Wed, 8 Jun 2022 12:41:53 +0000
> as far as I understand, the recceiver takes the messages of the reccasters and stores them in an sqlite file.
> how does the channelfinder java software access this information?
See the example *.conf files in https://github.com/ChannelFinder/recsync/tree/master/server
You can run it with `procs=show`to just print the info,
`procs=db:sqlite3` to use sqlite,
but the main use case it probably `procs=cf` where it uses the channel finder.
>I'd like to run two instances of the recceiver and only one channelfinder.
You just run as many recceiver instances as you like, all with procs=cf and pointing to the same channel finder.
You likely need to run one recceiver instance per subnet, since IOCs and recceiver find each other via broadcast messages which are typically limited to a subnet.
-Kay
Re: [EXTERNAL] Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address William Kirstaedter via Tech-talk
Re: [EXTERNAL] Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address Michael Davidsaver via Tech-talk
Prev: Re: dbLoadRecords and substitute Mark Rivers via Tech-talk
Next: Re: [EXTERNAL] Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Hartman, Steven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: dbLoadRecords and substitute Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Next: Re: [EXTERNAL] Re: Recsync: RecCeiver Server announcement contains Broadcast address instead of server ip address William Kirstaedter via Tech-talk
