1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: ADEiger R3-4 released
Date: Fri, 10 Jun 2022 21:55:24 +0000
Folks,
ADEiger R3-4 is now available.  This is from the release notes:
* Added a new Continuous mode choice for TriggerMode.  In Continuous mode acquisition continues
  indefinitely once it is started, until the Acquire record is set to 0 (Done).
  If NumImages=1 and NumTriggers=1 then acquisition is rather slow, about 1 Hz,
  because of the overhead in the detector server.  However, if NumImages or NumTriggers
  is greater than 1 then it will collect NumImages*NumTriggers images quickly, and then have
  about a 1 second delay before collecting the next set.
* Fixed a problem where the AcquireTime, AcquirePeriod, and ThresholdEnergy would not have the
  previous values when the IOC restarted.  This is because these can be set automatically when
  other parameters are changed, and so the readback values did not match the drive values.
  Added the asyn:READBACK info tag to these records so the drive values update when the
  readbacks are changed.  The correct values are now saved with autosave.
https://github.com/areaDetector/ADEiger
https://areadetector.github.io/master/ADEiger/eiger.html
Prev: measComp R4-0 available Mark Rivers via Tech-talk
Next: Re: Testing Rocky Linux with EPICS Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Allowing localhost in access control files Simon Rose via Tech-talk
